My TZ loads 4 balls into gumball. The game has been restored by TNT. Could this be the Geneva switch on the gumball or a trough issue? Any suggestions would be appreciated
**Assuming you only put 6 balls into the game**, it's a bad trough switch. Check Trough #4.
If you put 7 balls into the game, then the game is doing what it is supposed to, *regardless of the adjustment option specifying # of balls in the gumball*. You can take a ball out, or change the Adjustment to say 4, and have fun.
Quoted from Rob435:There’s 6 in game. 5 steel in ceramic. I’ll check trough 4
If you put it into gumball test mode, you will be able to see all of the (in this case) important switches.
This page was printed from https://pinside.com/pinball/forum/topic/tz-gumball-loading and we tried optimising it for printing. Some page elements may have been deliberately hidden.
