So was switching bulbs on my TZ and must have blown something...
Getting a "Ground short Row 1 is stuck closed"
When running test it says the same for rows 3,4,5 and 7 as well and ball popper opto stuck and clock broken.
I’ve then Disconnected some switch connectors from the CPU.
When J206 and J208 are taken off cpu board all “ground shorts” are gone. When I run test, it now only says clock broken and ball popper opto stuck.
Take off J212 and J205 (J206 and J208 are still off) get a Error of “replace fuse F115 and F114”
Looking at Replacing the U20 and U14— from. What I’ve read.
Had been working 100% before , so I’m guessing I shorted out something. When I changed the bulbs.
Any ideas or help? Am I on the right track?
