Just got my GI OCD board from LED OCD installed, and have had a chance to play around with it some. It is installed in a TZ. I really had no idea how much I was missing until I installed this board!
Most of the experience has been positive, but the choice of LEDs used in the GI will have a big impact on your experience.
First, it appears that my choice of using the PinballLife premium ghostbuster frosted dome LEDs for the GI may not have been the best choice (they were installed before I even knew about this upgrade board). The non-ghosting nature means that they start to flicker or shut off when you get them too dim. I'm finding that 5% gives flickering, anything below that is pretty much totally off. The backbox LEDs are all single-LED and they seem to respond better at the lower levels. However, I wanted warm white for the playfield GI, and I found that the PinballLife single LEDs were all too greenish for my tastes. The ghostbuster warm whites are much closer to the tone you get with an incandescent.
Next issue that I ran into is the clock. I've had a PinballLizard LED board in my clock since 2002. It uses four SMD LEDs. Unfortunately, they are DC, and as pointed out in the GI OCD instructions, you may have to reverse polarity in any DC LEDs you are using. Of course, the clock LEDs are all the wrong polarity, which meant I had to remove them and resolder them in the opposite configuration. Would not have been a terribly big deal except I ended up lifting the pad on the last LED (it is ALWAYS the last one that has a problem. ALWAYS.) I was unable to hack anything together quickly to attach that last LED so I decided to put in a spare ghostbuster remote LED into its place. Of course, the color and brightness is not even close to a match. I've never liked the cool white that the PinballLizard board gave, it didn't match at all with the rest of the lights, especially when they were incandescent. Seeing it with the warm white in there looks much nicer, and matches the rest of the GI. So I guess I'd like to know what others have been using in their TZ clocks? I'm about to dissect a PinballLife quad warm white, and solder in its individual LEDs into the normal PinballLizard locations (after I create some semblance of a new pad for the one I lifted). I think that will work perfect here.
Speaking of the clock, that is one place where the GI OCD really makes a huge difference. I've been used to seeing my clock blink on and off during clock chaos, but with the GI OCD, you get a "pulsing" effect that is way cooler, and probably is what it used to do when it was using normal lamps. It's been so long since I've seen one with lamps that I forgot.
