I was hoping someone could help me figure out what's wrong with my TZ game. The flashers don't work, so naturally neither does my gumball motor, which renders the game unplayable. I checked F111 and whether J125/J107 are plugged in properly, the connectors appear to be plugged in well and the fuse is fine. I checked my manual for the fuse with the flashers and it says that F111 is a flasher secondary - I would assume that means there's a primary, but it's not listed (plus all the fuses in my driver board seem good). One other observation - intermittent resets, bad power to the logic board? They happen sporadically, but could the two problems be related? On my way to grab my multimeter from a friend, couldn't get any reading but will update once I get back.
