So one day while I'm playing my tz, I shoot the ball into the slot machine and the ball doesn't kick out, opon inspection, I find that the wire strands at the solder point of the coil had broken off leaving one or two and I thought that was the problem. After cutting, stripping and soldering, I find that wasn't the problem. When I am just about to test if my fix worked, I drop the balls back in and find that the trough coil isn't kicking the balls over so I go into test and check the high voltage section of coils (1-8) to see if they are working, I find that at 4 or so are dead. I'm looking in the manual and track down the fuse for 1-8 (f105) to only find its fine. I have no clue what's going on. Any help would be appreciated thanks
