Hi everyone,
New here , my name is Marco, I m 30 and I write from sunny Italy!
I have recently finished a full restoration on my Tz and the last bit missing is the clock..
I have checked the clock board which is an original one and I have reflowed everything and changed a couple of components / installed leds instead of the original lamps.
In test mode the clock is working perfectly, every opto is registering and the displayed time is always correct. Works weel forward and backwards at both speeds.
During gameplay when i activate a mode in which the clock is activated, it starts spinning but suaddenly it resets to 12 o clock and the credit dot is shown.
Odd thing I noticed is that usually it stops and then resets when I press any of the flipper buttons.
If I enter the menu and then exit, the clock resets and the credit dot disappears..
Things I have checked:
- wire harness / connectors are good
- optos cleaned
- put a couple of spacers in the clock shaft as to eliminate any play in the clock hands / better hsnd movement = better opto operation
- Clock gears properly aligned
Things I still havent checked and I suspect as possible causes:
- 12V quality- but all the other optos are working 100%
- 20 V quality - could it be the motor working at a too high / too low voltage and so spinning too fast or too slow?
Any advice/help is appreciated
Thanks!!
