Hi everyone, I was hoping someone might help me with the following problem:
I'm working on a mostly functional twilight zone, and my clock is showing some strange behaviour. It is completely functional in every test and mode in the game, except for Clock Chaos. When I reach Clock Chaos, the call out plays and runs on the dmd, while the clock moves counterclockwise into the 6:00 position. However, the clock stops moving as soon as the call out finishes, pointing to roughly 6:55. As soon as it stops, the credit dot appears, and the clock stays dead until the end of the 3-ball game. When I interrupt the game by starting up the diagnostic menu I get the "clock is broken" message. Running the clock test shows no malfunctioning optos, and after one test the credit dot disappears again and the clock works normally. Also, simply starting a new game after the "clock chaos" problem game resets the clock, and everything functions as normal until I hit the next clock chaos.
I'm running rom L-4, and have recently installed a replacement clock board (Ingo Kramer's, which I'm very happy with). Since my old clock board was not functioning, I don't know if this behaviour was already present before I replaced the board. I don't think Ingo's board's the cause, primarily because the problem is so specific! I was wondering if you have heard of similar stories? I browsed the pinside site and I found one person with the same problem, but unfortunately he hasn't solved the problem so far.
Do you happen to have any advice? Thanks in advance!
Cheers,
Nico
