Has anyone ever had this problem? I can manually move the Diverter fine, checked all screws on ramp and they are tight. The underside is also screwed tight to the playfield. The Green coil AE-26-1200 is correct as well. Basically, whenever the coil activates, its shakes the whole ramp, causing a fast ball to fall off the ramp.
Any ideas? I am guessing I can just replace the coil at this point but i didnt know if anyone else had this problem or if all TZs shake the ramp when the coil activates.
