There is so many things to try listed here I'm almost scared to post anything but I'm going to anyway as I just cant help myself.
EDIT: <paragraph removed as I really spoke my mind here on what I read in this topic>
WARNING RANT COMING!
You know whats missing here...
There is not a single voltage measurement posted from the OP nor requested by anyone. The best that was done was he was pointed in the right direction by LTG so its assumed that these measurements are good as the OP posted he performed the procedure and found no issues; yet everyone assumes that there is a low voltage problem because they seen it all before and go through all the steps to correct this issue with absolutely ZERO voltage measurements. Based on this post:
Quoted from marioparty34:
Thanks LTG. I went down the list of what I can do and wasn't able to identify the issue. Guess it's time to call a professional.
I feel we did nothing to assist the OP to understand or diagnose his issue as his problem may actually be as simple as a loose ASIC ... but there is no way to know
END RANT.
I'm just going to ask three question of marioparty34 and am not going to post any more in this thread.
1) What was your voltage measurements at TP2 on the Power Driver board?
2) What was your measurement at pin 32 of the game ROM, or on pin 2 (center pin) of U10?
3) If you remove all connectors EXCEPT J210 from the CPU board, does it give you the same reset sequence as seen in your video or does D20 blink normally?
