My tz played great for months, not one issue, suddenly during one power up, she started blowing f105. I have looked at all the solenoids on that matrix, nothing's looks out of place. Any thoughts?
So when you power on the game does a coil lock on before the fuse blows? If so, the transistor or coil has an issue and is causing it to blow. If not, does the fuse blow if you remove the solenoid connectors from the power board and power up with them removed? If so, internal board issue. If not, check each pin in the connectors for short to ground with a dmm. Check each transistor tip to ground for those coils. Tip102/122 transistors test tip to ground for shorts.
Nothing locks or at least it doesnt have time to. Which connectors should I unplug to isolate the board?
You can look for them in the manual in the back. The board is also labelled. I think they're along the middle bottom row.
Quoted from R8f1k:I have no manual, unfortunately.
I will remove the bottom row
www.ipdb.org
Manuals are posted on ipdb. Gotta learn to help yourself a bit
Totally forgot about ipdb having the manuals. I will have to print them out.
Anyway, still blew the fuse with the bottom row unplugged
Keep in mind that Bally/Williams fuse designations for solenoids are probably wrong more often than they're right. Don't isolate your search to just the solenoids listed for that particular fuse.
Rob Anthony
Pinball Classics
http://LockWhenLit.com
Quality Board Work - In Home Service
borygard at gmail dot com
Quoted from R8f1k:Any ideas on what else to look for?
F105 will be for solenoids, you need to find the one that's shorted, has a shorted diode, or driver.
Pull all the connectors off of the bottom of the driver board and power on. If F105 still blows, you have a locked on driver. With the connectors still off, test continuity to each TIP102 tab to ground. The one that shows continuity is shorted.
Rob Anthony
Pinball Classics
Well, did you look at the manual? That fuse controls sol 1-8 which are located on J130, which is not on the bottom row. Unplug that one and then check.
Quoted from Borygard:F105 will be for solenoids, you need to find the one that's shorted, has a shorted diode, or driver.
Rob Anthony
Pinball Classics
Wow that looks almost exactly like what I said to do a couple posts up.
This page was printed from https://pinside.com/pinball/forum/topic/tz-blowing-f105-solenoids and we tried optimising it for printing. Some page elements may have been deliberately hidden.
