(Topic ID: 224048)
TZ: Are these screw heads normal?
By Claster
5 years ago
  • 16 posts
  • 11 Pinsiders participating
  • Latest reply 5 years ago by DNO
#1 5 years ago
Like most folks, I'm not the original owner of my TZ machine. I noticed two odd flathead screwheads on the playfield, in the left spiral ramp. (see photo below) A few times, but not all that often, a ball will get stuck on the far one. It's probably become magnetized due to its proximity to the magnet there, but that's just a guess. Seems weird to have exposed screwheads in the path of the ball, but I don't have another copy of the machine to compare it with. Are these supposed to be here? They're holding the big solenoid that drives the ball diverter. Thanks in advance.
Bob
#2 5 years ago
No, that's from a previous hack. Unfortunately nothing goes through the playfield there which is why is gets stuck...
#3 5 years ago
Yeah, that's about what I expected. So, without those screws, how is the big solenoid for the ball diverter held up?
#4 5 years ago
Quoted from Claster:
Screws below the playfield hold the bracket to the playfield.
#5 5 years ago
Here's what it looks like normally in that area.
#6 5 years ago
Sigh. So, curses on the idiot who made such an inept repair, and even more curses on the crook who sold me the machine without disclosing this to me. I guess I could use some plastic wood to smooth over those screw heads, and a little paint to make it look close to what it should.
Damn.
#7 5 years ago
Damn.
And then hope you never need to access that bracket.
Who sold you the game?
#8 5 years ago
Damn.
I'm thinking something simple like mylar might prevent ball hangups.
#9 5 years ago
Quoted from snakesnsparklers:
I would go with mylar too before using something that would probably make it look worse.
#10 5 years ago
I am also wondering if pop bumper screws could be a good fix as you could get them fairly flush with the surface. Mylar on top is also a good idea.
Sorry to see this - no reason for hacks like this.
#11 5 years ago
*shudder*
Freakin' operators..
#12 5 years ago
Damn.
It sucks, but don't beat yourself up. With everything happening on a playfield, things sometimes get missed. It's even possible the previous owner did not know either. It's just a lesson learned, but as others said, I wouldn't get too crazy altering anything as it might look worse. Personally, I would paint the head of the screws so they don't stand out and then put mylar over them.
#13 5 years ago
Yeah, that's the plan. And it's very low on the priority list. I've played the thing over a thousand times and the ball got stuck there only twice. A little plastic wood to smooth it over (the screws are a bit recessed), some gentle sanding, a little paint to make it look normal, and a small mylar patch will serve the main objective, which is to keep it from pissing me off! In fact, if I use the white Plastic Wood, I'll only need one color of paint, the midnight blue. Thanks, all. You guys are amazing.
#14 5 years ago
I had my Tz strip the wood and was not able to really get screws to grab w the normal methods.
What I did was just rotate the solenoid bracket a bit, and screw into fresh wood, worked fine, still does, location play.
If you did the same, you could just remove those screws and repair the holes.
#15 5 years ago
Quoted from DNO:
just fill the holes with toothpicks or bamboo skewers. that will fix the original holes
#16 5 years ago
Quoted from Marvin:
My go-to is the Q-tip shaft, I tried and it just kept stripping and coming loose again. Wood glue gets rock hard and takes too long on location.
Grabbing fresh wood worked well, and it's under the pf anyway.
At least I didn't go the route the op has to deal with.
$ 95.00
pinballmod
$ 109.99
Professor Pinball
$ 125.00
$ 132.00
$ 43.99
Lee's Parts
10,350
Ontario, CA
$ 79.50
$ 34.99
Rubber/Silicone
NO GOUGE PINBALL™
$ 1,059.00
$ 45.00
Just 3D Mods
Pinball Photos LLC
YouBentMyWookie
$ 73.00
Pixels Arcade Games
$ 399.00
$ 12.95
$ 24.00
Various Novelties
Pinball Photos LLC
$ 49.99
pinballmod
9,950 (OBO)
Centerport, NY
$ 129.50
7,500 (OBO)
Fairfield, CT
$ 24.00
Various Novelties
Pinball Photos LLC
$ 62.00
€ 75.00
PPmods
$ 115.00
pinballmod
8,800
Uniontown, OH
This page was printed from https://pinside.com/pinball/forum/topic/tz-are-these-screw-heads-normal and we tried optimising it for printing. Some page elements may have been deliberately hidden.
