(Topic ID: 270046)
TZ 3rd Magnet or Not
By Pintopia
1 year ago
  • 43 posts
  • 19 Pinsiders participating
  • Latest reply 1 year ago by Billy16
Topic poll
“TZ 3rd Magnet or Not”
  • Stick with the 2 Magnet Version 19 votes
    48%
  • Pursue the 3 Magnet Version 21 votes
    53%
(40 votes)
#1 1 year ago
I’m going to be starting a TZ full restoration project. (Game arrives today ) I’ve been debating on purchasing the 3rd magnet playfield vs the 2 magnet version.
I understand the amount of additional work installing the 3rd magnet requires and I’m technically capable.
My question is for those that have played both is the third magnet option worth pursuing?
Thanks Don
#2 1 year ago
Why wouldn't you? Go for it.!!
#3 1 year ago
Will the third magnet make it worth any more when you are done. Is it worth the extra work?
#4 1 year ago
I am in the middle of the project now. I started by buying the 3rd magnet playfield so in a way I was committed a long time ago when I purchased it.
There are a lot of pieces to this puzzle. Unless you can procure the items cheaply, I have found it to be pretty damn expensive for the marginal gameplay differences. Yes it is cool when three balls are frozen, but it is a very rare occurrence when playing.
You need to do some serious electrical work as well. Plus from what I have read you take on the risk of messing up your other boards. If I could do it over again, I would skip it. Just my opinion.
For what it is worth, here is a link to a spreadsheet with notes on the restore. On it is a 3rd magnet tab with info on what and where I got stuff. I did already have the 3rd magnet kit which had the optos and the electronics for the high power board.
https://docs.google.com/spreadsheets/d/1cpPt7E9-jpGFBFcxws7F77GraEo-IWlafqXq96BlAQw/edit?usp=sharing
Dave
#5 1 year ago
I did it years ago and it wasn't that tough. You say you are technically capable; to me this is a no brainer. It's worth it. Just do it.
#6 1 year ago
Quoted from John_I:
What he said. Do it...
#7 1 year ago
There may also be a 3rd-party ROM in the future that takes advantage of the 3rd magnet more often in Multiball Start.
#8 1 year ago
I'm not a massive fan of it and wouldn't go out of my way, but if you already have it broken down then for sure do it.
#9 1 year ago
Quoted from Coyote:
If this is true, it would be awesome. I love magnet play (big CV fan). So the more interaction with them, the better.
Either way, I wish the OP the best of luck if he takes it on. For me it was a little more difficult since I don't have as much tech background.
#10 1 year ago
Quoted from iamabearsfan:
That's always been my understand. Cool feature but doesn't change much gameplay. Personally, I would rather have a stock TZ and not deal with any extra maintenance headaches or gremlins from someone hacking it in. I don't think it would be hard selling a stock TZ being a desirable game so don't think it makes much difference in the end.
#11 1 year ago
Worth it if you have an early sample with most of the work already done for you. Otherwise I'd skip it.
#12 1 year ago
I have all the parts, but too much of a whimp to drill the playfield
#13 1 year ago
Quoted from metallik:
Mine was early production that had been easy to convert. It really does not add all that much to the gameplay after you have seen it once or twice, I can understand why they cut this out of the production run.
#14 1 year ago
Does the latest home ROM support the third magnet or do you need to run an earlier version?
#15 1 year ago
Quoted from Billy16:
One issue is the fact you have to cycle the powerball through the gumball at least once per powerup before the multiball-freeze feature is enabled... the software needs to know the powerball is in the gumball and not the trough. If you just want to power up and play and see the effect.. not happening.
Quoted from RobertWinter:
The latest home rom TZ 9.4H is the one that supports the magnet grab feature. Older revisions don't do anything. Once Pat figured out the 3rd magnet wasn't needed to help stop autolaunches, it got costed out and removed from production code. My sample game had prototype code in it that did nothing with the magnet. Ted Estes added code to the home version 9.4h to do the grab trick (and use all three magnets during The Spiral).
#16 1 year ago
Thanks all for the reply’s and a special thank you iamabearsfan for the spreadsheet. It’s always appreciated when someone goes the extra mile to document for others. Thank you
#17 1 year ago
Quoted from Coyote:
This post should be stickied for all of Pinside.
#18 1 year ago
Hadn't heard this as the reason. I was told it was just for cost savings, since the game could do (just about) everything with two magnets.
In either case, this is one of the things Ted was working on with the magnet toss back in pre-prototype code. Was told that it was dropped because of difficulty (in-code) handling it with all the different qualities of machines out there. (PF angle, weak coils, dead magnets, etc.)
(Edit: This is on my game, running a beta of 9.4H.)
#19 1 year ago
Quoted from Coyote:
What's the scoop on this?! 1st I'm hearing a potential update in ROM is coming!
#20 1 year ago
Quoted from Kwoody51:
No. There MAY be one, but it's a ways off. I was working with someone on zapping the code out of the beta to do the tossing, but something came up and it's on pause now. However, hopefully, eventually, something will come of it.
(Edit to add: Point is not to give false hope, or start internet rumors. )
#21 1 year ago
Quoted from Coyote:
Fake News!!!
I for one would be willing to pay for such an upgrade though!
#22 1 year ago
I kind of recall something went awry and Ted put a stop on any future updates?? I would not even know where on here I read this.
#23 1 year ago
Quoted from chad:
Was that when someone bootlegged his home rom to accept monies?
#24 1 year ago
Quoted from TheLaw:
Sounds familair. But not 100% sure.
#25 1 year ago
Quoted from Coyote:
From much discussion back in the late 90s, the original reason for two on the right was to ensure autolaunches were stopped on the right side. Pat didn't think one magnet would be enough so two were originally allocated. When one proved sufficient, the other was costed out. You're right in that other tricks were in the works but difficult to implement due to variances in games. Could also be some tricks needed all three magnets... it seems once the 3nd magnet got removed, any tricks except the Spiral stops and "shot helpers" were removed. I assume the 3-ball freeze trick we have now was the only one that performed reliably? (and even then sometimes the ball ejected from lockup will stick to the upper ball and not roll to the lower right magnet...)
There was a Gameroom mag article on this back in the 90s, quick search didn't turn it up though.
#26 1 year ago
Quoted from TheLaw:
Yea the hacked TZ9.4h was unfortunate. "We just can't have anything nice..."
#27 1 year ago
Quoted from Coyote:
Crazy idea, but what about a "Gofundme" to get a more radical ROM to take more advantage of the 3rd mag? Crazy idea???
#28 1 year ago
I have seen and played a TZ with this mod and it is very cool. It’s “Money!” as a friend of mine used to say. I would do it. Also consider this. Your gonna have the game already broken down. Do it now otherwise you may never get to it again. Also, Mirco playfields are available if you mess up your drilling effort. There is really little risk at this point.
Good luck.
#29 1 year ago
Quoted from chad:
Quoted from chad:
Yeah - in the TZ thread I linked to the RGP post BY Ted that pretty much explains it all:
https://groups.google.com/forum/#!msg/rec.games.pinball/5exaK_Q8-Pc/70Tl7ojZvBAJ
Anyways, this is off-topic. Sorry.
#30 1 year ago
Quoted from Coyote:
Just read that whole thread. Makes me sad that someone hacked his work. I was a developer for a lot of years and I can empathize in that source code is sacred. Is Ted Estes around still? That thread is 20 years old now. It makes me beyond sad that he still had ideas to make other releases and it died because of someone hacking his code.
At this point, do you think the IP of pinball code is still a sacred cow with Williams? That to me is the sticking point. Would it be possible to at least approach Williams on such an initiative to continue Ted's work (if he could great, if he is not able to or is worse passed, obviously it would have to be someone else). My point is that the alternative is the code is dead for ever. Not that it isn't great code, but gosh, I really wonder what he had in store still. I wasn't kidding when I talked about a gofundme. If the right incentive was there, I wonder if we could re-kindle a flame. I know, I am probably pipe dreaming here.....but that is my personality
#31 1 year ago
Works for JJP in Chicago.
#32 1 year ago
Ted won't say yes. I can't speak for him, but .. I'm willing to put money down, "No". We would need to contact Rock @ PPS now.
#33 1 year ago
Ted is still rocking awesome code at JJP, worked on Hobbit, Dialed In, Wonka, POTC (I think?).
#34 1 year ago
I like the idea of a go fund me effort to continue the development of the third magnet code. However I believe we would need permission or a partnership with the license holder to initiate such an effort.
Perhaps if a new topic was started to rally the pinball community to get behind such an effort?
#35 1 year ago
You don't need permission or a license. You just can't distribute the rom. What you can do however is make a patch of your new custom rom that can be applied to the 'stock' rom. This patch would contain no copyright assets. It just makes it slightly harder for the layman to do. But if they've got a rom burner then they can probably figure out how to apply the patch. It's not hard.
There's a guy who has done this for a bunch of games. hook and TFTC come to mind. He's done a bunch of others too though.
#36 1 year ago
Quoted from pinball_ric:
Yeah, and he took them all down now, because of PPS.
#37 1 year ago
Quoted from Coyote:
No he didn't. PPS doesn't own any Data East rights.
https://www.pinballcode.com/
#38 1 year ago
We're talking WMS and TZ here. Not sure why you decided to bring in DE. The two folks that were releasing patches for WMS games (whom TZ is made by) took their patches offline, because of something going on with PPS. So it wouldn't matter what anyone doign with another manufacturer's code does, as if someone here were to release a patch for TZ, they, too, would likely be asked to take it down and have a talk with PPS/Rick.
#39 1 year ago
Quoted from Coyote:
They can be asked, but producing patches (and not full rom distributions) has been considered legally acceptable.
#40 1 year ago
Quoted from mjenison:
Quoted from Coyote:
Not sure if I'm speaking a different language, or maybe I'm just confusing people. I'm not arguing one way or another. Just stating facts.
#41 1 year ago
Quoted from Coyote:
I think he was responding to his own point that there are updates for Hook and TFTC. But yeah, all B/W games are no longer hosted.
#42 1 year ago
Providing software patches is well established to be legal. PPS can threaten people if they like but they don't have a leg to stand on. If they did try to do any legal action there's a good chance the EFF would step in to defend the author.
Additionally you can still get the LED ghosting patch for WPC games. That hasn't been removed.
#43 1 year ago
One thing PPS has always been good at--throwing their (perceived, perhaps) weight around.
