My domino is almost done(lol) anyway I have two problems left the target and rollover value control relays and alternating relays are all locked on
These are the relays attached to the underside of the playfield
The rollovers are all functioning and score
I adjusted the relays and all the blades seem to be opening and closing as they should
My other problem is the roto target doesn’t score
I took it out and cleaned it seems to be making contact with the brass rivits when it stops
If I manually activate the roto target relay it scores
Is there a switch on the score motor that completes the circuit
