(Topic ID: 225618)
Twister - Trough Issues
By FunkyFreshWalrus
5 years ago
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 5 years ago by wdennie
#1 5 years ago
This trough issue is driving me crazy! Every once in 30 or so balls, the trough lock mechanism gets hung up on a ball. The trough lock mechanism moves and operates very smoothly. There are not divots in the trough that I can feel or see. The balls were very mildly magnetized, but with replacements it still happened. The replacements also became mildly magnetized. I am awaiting magnet friendly balls, but even still I wouldn't expect them to be come significantly magnetized within a few games. Are the magnets in this game really that strong that they can magnetize balls after a few games?
So far I have:
Replaced all trough switches
Rebuilt and reflowed opto boards
Replaced connectors on the wire harness to optos
Cleaned and replaced sleeve on Trough lock mechanism
Tried several different strength springs on the trough lock mechanism
See attached photo where the lock mechanism has become hung up, and does not return to home position completely. In this state the game sees no balls (unless one is locked elsewhere). The balls are all sitting just in front of where they would normally, so the switch rollers are up. No balls are in the trough up kicker. The coil looks a little toasty but seems to operate just fine.
#2 5 years ago
Does the coil sleeve extend through the coil bracket? I see the return spring but i can't see the coil sleeve under the spring? If the coil sleeve is to short the coil will cock and the plunger won't return properly.
#3 5 years ago
Yes, it does extend through the metal bracket. You can see a tiny sliver of it under the spring.
#4 5 years ago
Did the sleeve come out of the coil easily? Just wondering if when the coil gets warm if it's expanding and causing the plunger to bind?
#5 5 years ago
No, the old sleeve had to be broken apart to remove it. I will try a new coil.
#6 5 years ago
Quoted from FunkyFreshWalrus:
You should also replace the coil stop bracket.
sleeve came out hard because the coil got overheated.
$ 27.95
$ 39.00
Arcade Upkeep
Newcastle, OK
$ 54.99
$ 54.99
$ 18.95
$ 24.95
Mitchell Lighting
$ 54.99
arcade-cabinets.com
$ 17.00
Nordic Pinball Supply
$ 54.99
$ 18.95
$ 23.95
$ 54.99
$ 18.95
This page was printed from https://pinside.com/pinball/forum/topic/twister-trough-issues and we tried optimising it for printing. Some page elements may have been deliberately hidden.
