Came across this hour-long interview with RM from 2019. Back then, Deeproot had THIRTEEN titles 50% or more completed. Imagine how many they must have now!
https://soundcloud.com/kanedapinball/episode-420-robert-from-deeproot
Quoted from blueberryjohnson:Came across this hour-long interview with RM from 2019. Back then, Deeproot had THIRTEEN titles 50% or more completed. Imagine how many they must have now!
Hmmm.... episode 420. Coincidence?
Some Deeproot rent $ info?
60-month lease expiring March 31, 2023 (Renewal Options: None)
Security deposit = $212,714.53
April 2018-2019 = $553,631.52
April 2019-2020 = $553,631.52
April 2020-2021 = $553,631.52
Rent expenses through April 2021 = $1,873,609.09
April 2021-2022 = $571,584.88
April 2022-2023 = $587,033.12
Rent expenses, full lease term: $3,032,227.09
Less deposit (if returned): $2,819,512.56
Lease Type: NNN
*Tenant contracts for Electricity, Janitorial, HVAC, and Landscaping. Tenant is responsible for HVAC repair, replacement, and maintenance.
Without wanting to re-open the can of worms, I was looking through the GnR schematics the other day. All the LED insert boards are node boards, connected to the main board via RJ45 (ethernet) cables, and using I2C as the comms protocol. I2C is a serial protocol.
gstellenberg Just to understand the argument a bit better - you're not saying that a serial comms protocol like I2C being used in this way is a dodgy architecture right, since the LEDs on those node boards will still be driven in parallel using LED drivers? Your argument is against LEDs connected to each other in series and driven using something like WS2812 (ie LED strip lighting) ?
Quoted from stumblor:Without wanting to re-open the can of worms, I was looking through the GnR schematics the other day. All the LED insert boards are node boards, connected to the main board via RJ45 (ethernet) cables, and using I2C as the comms protocol. I2C is a serial protocol.
The problem with WS2812 chain is you just shift out the data and "pray" every led reads it and passes it on without getting corrupt, there is no error checking that i am aware of, just shift it out and hope it works, so can be prone to issues if interference is about. I2c / other buses should have some sort of error checking so if a packet does not make it or fails it should try again which makes them a bit more reliable.
Quoted from russdx:The problem with WS2812 chain is you just shift out the data and "pray" every led reads it and passes it on without getting corrupt, there is no error checking that i am aware of, just shift it out and hope it works, so can be prone to issues if interference is about. I2c / other buses should have some sort of error checking so if a packet does not make it or fails it should try again which makes them a bit more reliable.
GnR uses ultra fast I2C, which from what i understand is also fire and forget...
Quoted from seenev:Here you go! [quoted image]
Robert had to put the LEDs* down because LEDs are for closers only.
*pronounced as “beds”
Yes 2812s are indeed susceptible in this way and I’ve personally seen data corruption with longish leads. I2c is a better solution, SPI for long leads to the controller and high data rates probably the best. The other disadvantage of 2812s and pretty much all led control systems is use of pwm which inherently means one has flickering to control brightness. Granted not flickering all that perceptible, but flickering nonetheless. Constant current controllers are a pricey solution but take care of a lot of this issue.
Quoted from pookycade:Yes 2812s are indeed susceptible in this way and I’ve personally seen data corruption with longish leads. I2c is a better solution, SPI for long leads to the controller and high data rates probably the best. The other disadvantage of 2812s and pretty much all led control systems is use of pwm which inherently means one has flickering to control brightness. Granted not flickering all that perceptible, but flickering nonetheless. Constant current controllers are a pricey solution but take care of a lot of this issue.
Long as your pwm is fast enough should be no flicker (to the eye), id be very surprised to find even Gerry's LEDs are not pwm by the fpga even though wired directly (Gerry would have to confirm that)
I really like the idea of the led strings or even everything on the string imagine each coil having its own tiny little pcb on the string with just data and power. Its just how do you keep it all EMI clean. Maybe fiber connecting it all together?
Meh. We use APA102 which have clock and data lines, a start condition, start frame per pixel and an end condition bit pattern. It is not dependent on pulse widths like a WS2812 Neopixel.
Also wow. 3 million burn on rent alone. So yeah, maybe they didn't spend the whole 35m but now I'm thinking it's probably closer to 20 than 10.
And they could even get a single prototype to work. Pathetic. Go home boys, you're drunk.
They were all ‘50%’ complete because Jpop told RM that’s how complete they were. Which means, they were all foam core with with blinking lights... so more like 5% complete.
Quoted from stumblor:you're not saying that a serial comms protocol like I2C being used in this way is a dodgy architecture right, since the LEDs on those node boards will still be driven in parallel using LED drivers? Your argument is against LEDs connected to each other in series and driven using something like WS2812 (ie LED strip lighting) ?
I2C and SPI are also single-ended digital buses not designed for noisy (EM) environments, but an LED implementation using one of them is more likely to avoid issues because you're likely using just a handful of slave devices that all receive the same data at the same time. They're still not the best choice if you're seeking noise immunity, but they're definitely better than long chains of serial LED devices. Yes, you can theoretically add error detection and correction on top of I2C/SPI, but few do, as it adds complexity to each device and reduces refresh bandwidth.
Quoted from pookycade:The other disadvantage of 2812s and pretty much all led control systems is use of pwm which inherently means one has flickering to control brightness.
This really just depends on your refresh rate. Anything above 30fps is probably fine, 60fps for sure (just like 1080p HDTV). Our boards refresh parallel LEDs at 1000 fps and run serial buses as fast as the protocol allows (therefore limited only by the number of LEDs in the chain). Most often any flicker you see in some systems is from software-controlled color fades in systems that can't send new color data to the chains fast enough. Our PD-LEDs do fading in hardware to avoid that.
- Gerry
https://www.multimorphic.com
Quoted from benheck:Also wow. 3 million burn on rent alone. So yeah, maybe they didn't spend the whole 35m but now I'm thinking it's probably closer to 20 than 10.
Don't forget the 2 years or so (?) rent paid on the now closed Utah studio and the staff.
Wow, their San Antonio office seems swanky by the flyer. On site gym and cafeteria (you can see Robert's pinballs in the photo?)
They can advertise the manufacturing wing as unused for the next tenant
The SLC office seems/seemed more normal and about $30/sqft based off some light googling.
Quoted from TreyBo69:Wow, their San Antonio office seems swanky by the flyer. On site gym and cafeteria (you can see Robert's pinballs in the photo?)
I see a pin pod in the lab side, but that it. Minus the stuff in the break room.
Quoted from TreyBo69:The SLC office seems/seemed more normal and about $30/sqft based off some light googling.
How big was the space? The San Antonio office rate is < $14/sq ft
Rob's got a nice collection. Cool to see a Space Mission in there sometimes the noobs don't give much thought to the old stuff!
Quoted from benheck:That lab is WAY too clean. Ain't nothing goin' on in there!
Pack it up boys.
Perhaps jpop revolutionized the roomba, too
Quoted from blueberryjohnson:Perhaps jpop revolutionized the roomba, too
Well, he does suck.
When I go looking for deep root's facilities, I just roll down my car window and follow the smell of skankery, testosterone, Starbucks, and deceit...
Quoted from blueberryjohnson:Every family needs a pinball. Every pinball needs a family.
This quote has made me laugh since day 1 and was one of the first huge red flags I saw. At the time he was still talking "ferrari quality at hyundai prices" or whatever but it still just screamed to me that is was dumb words by a guy extremely out of touch with reality.
Quoted from Haymaker:This quote has made me laugh since day 1 and was one of the first huge red flags I saw. At the time he was still talking "ferrari quality at hyundai prices" or whatever but it still just screamed to me that is was dumb words by a guy extremely out of touch with reality.
Sadly, it would appear the deeproot family has sent this beloved slogan to the trademark orphanage
Yes if there's one thing every family needs it's a $6000 toy that takes up a much space as a couch.
I'm sure people on food stamps who've been on UE since last spring are ready to buy in!
What a colossal waste of money that facility is. How many employees did DR top out at in Texas? They could have built 150 games in a building the size of their cafeteria. If they manage to clear 1k profit on each game, they only need to sell about 3000 units to break even on the rent, at least.
Quoted from benheck:Yes if there's one thing every family needs it's a $6000 toy that takes up a much space as a couch.
Maybe he meant an actual pinball, like the ball bearing, not the entire machine
Quoted from blueberryjohnson:Sadly, it would appear the deeproot family has sent this beloved slogan to the trademark orphanage
https://trademarks.justia.com/875/31/every-family-needs-a-pinball-every-pinball-needs-a-87531117.html
In that case I'm claiming this slogan as my own.
Like the musician who tried to claim "Prince" when Prince became Symbol guy.
Trademarks are relatively inexpensive to obtain but what a waste of effort had they gone ahead with this. This is another example of them doing the easy, frivolous stuff and taking their eye off the ball.
have they trademarked "pinball is easy" yet?
Now 353 pages on ONE thread about a company who can't produce a single game.
I think its official Deeproot is now Seinfeld. You know the show about nothing.
Jerry Seinfeld became a BILLIONAIRE because of the syndication rights... I wonder if Deeproot could do the same?
A pinball company about nothing, and now Billionaires. Sounds about right.
Quoted from toyotaboy:have they trademarked "pinball is easy" yet?
It would appear not.
They did however register this one (unironically, one presumes):
https://trademarks.justia.com/882/82/pinball-for-the-88282791.html
Quoted from CrazyLevi:The Homer:
The car for the common man. (tm)
Deeproot:
The pinball for the common man. (tm)
Quoted from blueberryjohnson:It would appear not.
What’s really funny about this is - a trademark has to be “in use” to be issued.
As in, a company must have a product in the public domain that uses this trademark. I’m going to assume that it was abandoned based on a lack of a product using this TM in the public domain.
Quoted from CrazyLevi:I just discovered my parents’ sick stove has a pinbar!
That's the exact PinBar™ DR is using on Food Truck!
Quoted from CrazyLevi:Holy shit!!
I just discovered my parents’ sick stove has a pinbar![quoted image]
Looks like they're boiling water without a license.
Quoted from benheck:Looks like they're boiling water without a license.
They are preheating the oven to bake their water, which is not the best way to boil it.
Quoted from Lounge:What’s really funny about this is - a trademark has to be “in use” to be issued.
You also have to file with some sort of proof (we use streaming links, our DPK, digital flyers, and websites showing bookings), so they might still have just chosen to let it lapse
My parents too but as soon as I got hungry they told me dinner was meant as an internal goal and external expectation, not a promise of eating.
This page was printed from https://pinside.com/pinball/forum/topic/twip-is-deeproot-the-next-misadventure-or-a-pinball-revolution/page/353 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
