Hello everyone
Last night my TZ decided to stop sensing the powerball in the trough. And it gave me a switch 26 error.
I have been searching the internet, and reading up on the issue, but there is something i think i need clarified.
In my case the red LED on the driver board is constantly on. I then read in another thread on pinside that if i removed the connector to the sensor (coil) board and the LED was still on, this would mean that my driver board was fried. And when i disconnected the sensor board from the driver board, the LED stayed on. So i guess my driver board is shot...? Or is it...?
I wanted to check if the same was true for my working ToM. And this is where i got confused... On my ToM the LED is off until a ball passes the sensor. But if i disconnect the sensor board, the LED actually turns on. So it seems that if the "loop is open" the LED also turns on? And if this is true for TZ as well, the fault could just as easily be with the cable or coil on the sensor board?
So can anyone confirm: If i disconnect the sensor board from my TZ's driver board - should the LED be on or off?
Hope all of the above makes sense despite my poor english
