Quoted from markmon:Is this your only machine? Unfortunately, the new power driver board you refer to is probably a rottendog, right?
Yep, my only machine and yes, it does appear that RD boards are the only ones available. Super bummed to hear you say that your didn't work out.
Quoted from markmon:That being said, my opinion is that your issue could be power board related, heat related, or CPU board related. Also could be speaker issues.
So I'm down to 1) power board 2) CPU board (or chip?) or 3) physical speaker issue.
Quoted from markmon:Maybe you can describe the situation better. I believe the speakers in TZ are wired in one series. If one wire was flaky then the whole sound set up would cut out entirely.
The situation is as follows: the sound never 100% drops out...it just drops super low. I don't hear any loud crackling or anything that would indicate that a speaker wire is frayed and losing contact. It also isn't consistently a problem. I've had stretched of 15-20 minutes where I haven't heard any issue at all, then all of a sudden it's happening again. I can take an audio sample of the problem and put it on Youtube if that would make it easier to understand.
When it happens, the sound drops out for anywhere from 1-5 seconds at a time, sometime a little longer (total bummer for gameplay, as you can imagine). Then it comes back full force. Then a couple of minutes later it drops out again, sometimes a minute later and sometimes 10 minutes later. Totally inconsistent and hard to replicate the problem.
The machine is in my basement where it's quite cool all the time. I hadn't thought of playing with the backglass removed and the door open but that sounds like a good idea. I guess that would tell me whether it's a heat-related problem or not.
The guy who sold me this machine told me that the capacitors on the power driver board were replaced and they look brand new, so I'm less inclined to think it's a power driver issue. I guess I could break out the voltmeter and try testing them again, but I'm not sure I understand how a capacitor is properly tested. I know how to test for resistance and volts, but not sure how to test caps....
Testing the speaker wire configuration sounds interesting. Any thoughts on how I'd do this?
