(Topic ID: 196685)
Twilight Zone - Rocket Freezing
By MoDaisy
5 years ago
  • 7 posts
  • 6 Pinsiders participating
  • Latest reply 3 months ago by Gorgar666
#1 5 years ago
We recently got the TZ as our first machine and we are loving. We have noticed that when the ball falls into the Rocket Launcher it does not always "launch". Many times we have to wait a while for the system to realize that there is something wrong and then it runs through its tests until it launches.
Any advice on how to fix this?
#2 5 years ago
In the tests, select the switch test and confirm the switch works reliably.
Check the out the TZ owners club here:
https://pinside.com/pinball/forum/topic/twilight-zone-owners-club
#3 5 years ago
Quoted from Neal_W:
What he said...you just have a bad or flaky switch. Replace it or you can try to bend it up just a little to make it more sensitive. In switch test mode, test with a ball, not your finger
#4 5 years ago
keep in mind TZ does not have a high power shut off the coils are always on even during switch test.Like other members said could be a flacky/faulty/bad switch or your machine is not tilted properly meaning the back legs are not leveled at 6.5 or 7 slope the playfield has to be slanted
4 years later
#5 3 months ago
...switch works in switch test, coil works in coil test. but doesn't kick the ball out when I set a ball in there. I have not played the game, I'm in the beginning stages of first power on.
#6 3 months ago
Did you test the switch using a ball or your finger? Always confirm the test using the ball.
#7 3 months ago
Quoted from Steve_in_Escalon:
Wow bro. solved! Switch needed adjustments with the ball.
$ 43.99
Lee's Parts
Interactive
$ 69.95
pinballmod
Toys/Add-ons
$ 399.95
Pin Stadium Pinball Mods
Led
