Quoted from hockeymag8:Thanks for the tip!! The switch has connectivity and I unplugged J205 and built a jumper and was able to get the enter to work that way (thanks to the person that posted the wikipin link to how to test these switches!) so for sure the wiring is the issue as you suggest. Since all the other switches work do you know if that means it has to be the Orange and not the ground or could it be either or?
Edit: I'm confused by your statement, "The switch has connectivity..." If you tested continuity from the orange/gray wire at J205 to the switch and found continuity then there is no break in the wire and the below information probably won't help.
Yes, if I understand you correctly. You should try and trace the Orange/Gray wire from the switch to J205.
D8 is your enter switch. The manual (page 3-3) shows the wires as Orange/Gray and Black. If you disconnected J205 and jumpered pins 9 and 11 and got a result as if you pressed the enter button then tested your switch and confirmed it's good that indicates a problem in the circuit connecting the orange/gray wire. It goes through the coin door interface board between the switch and J205. I would check connectors J1 (pin 8 ) & J3 (pin 11) on the coin door interface board (page 3-31)
