The power ball sensor detects the absence of steel when parked in the exit of the shooter lane. When the ball is launched, the game will indicate "Power Ball" if that sensor does not sense a steel prior to launch.
The trough also uses an Eddy sensor assembly, located just past the trough switch. When the ball travels through the trough, it contacts that switch. If the Eddy sensor does not sense a steel ball immediately after the switch, the game assumes "Power Ball". If it senses a steel ball though, the game will operate normally.
An Eddy sensor at the shooter lane which is defective or positioned improperly will either tell the game that EVERY ball is a power ball, or it will never sense the power ball at launch.
In the trough, a sensor that's defective or positioned improperly will likely never recognize the power ball in play.
The shooter pickup has two wires on it, and a short cable. At the end of the cable is a tiny connector which is known to fail. On my TZ, I cut off the connector and soldered the two wires directly to the pins on the Eddy sensor PC board, to eliminate a potential connector failure.
