Quoted from Flato:Was hoping to find someone local to shop out my twilight zone but cant find anyone in the area at the moment, figured i would post to see if anyone can help if this is something i can do myself. In the Saint Louis Mo area if anyone wants to recomend someone.
Game generally wont start just goes to testing over and over and if it does shuts down as soon as you hit flipper.
Check switch 67, 75 76 f3
Depending on what needs to be done, shopping out a pin can be fun and rewarding. It also can be frustrating at times. If you want to try and fix it yourself, I highly recommend you go to pinwiki and read through the beginners guide and also the bally/williams wpc section. There is a lot of information there but if you read through it, you will gain a much greater ability to diagnose and repair pinball machines yourself.
To help you immediately with your problem, always start with simple fixes first. If there is some weird behavior that I come across, I always check fuses first, re-seat all connectors in the back box, and re-seat all ribbon cables. I check if there are any burn marks on plugs, wires and circuit boards. Give it a good look over to see if there is anything that doesn't look right. Often times pins can get back to working with just checking those few things. If not, you will then have to start researching what error codes pop up and how to fix them. This is were pinwiki really comes in handy. Don't be afraid to ask questions here on pinside as there are many awesome people here who are willing to help.
https://pinwiki.com/wiki/index.php/Main_Page
