Alright so I went through every pcb in the machine and derusted, tested, soldered, ran new traces for ones that are damaged.
I just finished going through every mechanism under the playfield, disassembling everything, derusting it, reassembling, repairing what needed to be repaired, then reattached it all. Installed all LEDs.
Game is "running". All the stuff above the playfield still needs to be shopped. There's still no sound but I think the speakers may be toast. I put a 9volt on the terminals and one does absolutely nothing the other makes this quiet popping noise that it also makes when the game is on. I ordered replacements because they need to be replaced regardless.
You can start a game and it will run, various coils and such work. There's a handful of lights that aren't working under the playfield, probably just needs some soldering or jumper wires ran.
There are no lights coming on in the backbox. I need to trace those wires and figure out where they plug into. When I first got the game about half would turn on.
Currently the plan is to go through the top of the playfield tomorrow and the next day. At that point it should be mostly playable. I ordered radcals and will be installing them on the spare cabinet I have and once that is done it will be time to move everything over to the new cabinet. Once that is done I assume I will have an extremely nice twilight zone example since I have literally gone through every single nut/bolt/screw/switch/mechanism and repaired or replaced or adjusted everything.
