(Topic ID: 63352)
Twilight Zone Owner's club
By Caucasian2Step
10 years ago
  • 15,189 posts
  • 945 Pinsiders participating
  • Latest reply 5 hours ago by jrcmlc
  • Topic is favorited by 499 Pinsiders
Pinside_forum_8036376_3779623 screw through playfield oops (a) (resized).jpg
8 key posts have been marked in this topic (Show topic index)
There are 15,189 posts in this topic. You are on page 27 of 304.
#1301 8 years ago
I forgot about your LITZ comment, buy the home ROMs.
They have a LITZ practice mode that allows you to do just that. However, it won't allow you to save the LITZ score while in practice mode. Otherwise, it operates the same as the commercial ROMs.
#1302 8 years ago
Double-post.
#1303 8 years ago
Quoted from Pale_Purple:
Looking for suggestions on your favorite mods/protection for TZ. What did you do to your machine that you love?
Always recommend Cliffy's protectors. Also like Pinbits gumball light.
Of course I am a little partial to my Slot Machine Kickout Light. It is interactive so it is only lit when the slot machine is active and the install is super easy plug and play.
http://www.leesparts.com/products/twilightzone-slotmachine-light.html
TZSlotKickoutBlue.jpgTZSlotKickoutBlue.jpgTZSlotKickoutGreen.jpgTZSlotKickoutGreen.jpg
#1304 8 years ago
Could someone here in the TZ owner club explain the why there is a gumball machine on the pinball? It is talked about like it is the central feature of the playfield.... but could someone tell me what it has to do with any TZ episode? It certainly does not pertain to any great classic episodes. Help me out here.
#1305 8 years ago
Quoted from wantdataeast:
The gumball machine is not in any episode of TZ. As for why there is a gumball machine, why shouldn't it be? its freaking awesome.
https://en.wikipedia.org/wiki/Twilight_Zone_(pinball)
#1306 8 years ago
http://www.ipdb.org/rulesheets/2684/tz-tie-ins.htm
all tie-ins explained, but gumball is just a bit of fun.
#1307 8 years ago
Quoted from Coyote:
And, where the heck does this post go? I have all the posts in my game, no open holes or anything...!
I think this is the post that's in the tear down pic below.
#1308 8 years ago
Just curious where you get & which color you use for your TZ leg protectors? Thanks
#1309 8 years ago
Quoted from lb1:
Huh, thanks. I'll have to put mine in now. Interesting..!
-Mike
#1310 8 years ago
Quoted from Coyote:
-Mike
On mine, it is actually right against the stainless steel gate with the double opto, and it's quite a tight fit.
#1311 8 years ago
For those who, like me, can't afford the gumballs people sell on ebay (are they made of gold or what?).
#1312 8 years ago
Where did you get that Chinese checker game?
#1313 8 years ago
Quoted from Plumonium:
He said at Target for $5.99 + tax
#1314 8 years ago
just finished 2 different plunger plates for the recess if anyone is interested like the Marshall Amp Plate
https://www.shapeways.com/search?q=swinksplungerplate&sort=newest
marshall amp / speaker plunger plate
2 different Twilight Zone designs
625x465_3875477_12280135_1443774383.jpg.png625x465_3875477_12280135_1443774383.jpg.png
625x465_3875457_12268565_1443694515.jpg.png625x465_3875457_12268565_1443694515.jpg.png
#1315 8 years ago
Quoted from Blindseer:
Then this is probably an old argument but I think if it is not related to an episode has no place on the machine... if they wanted to have a special ball it should have been shaped like the eyeball and painted in black and white, and delivered into play in a TZ episode like way... my 2 cents.
#1316 8 years ago
Will the game still work normally (other than saving settings) if the 3 AA batteries are out of the holder?
#1317 8 years ago
Quoted from Scout:
You're correct. The settings and high scores won't save, and you'll get a startup error, but the game will still play.
#1318 8 years ago
Just curious if there are capacitors I can change on the sound board that would make the game sound better?
#1319 8 years ago
Quoted from Cobra:
Game reboots when I get to LITZ. What is the fix? Anyone know? Also the DMD in it has a few lines missing so I swapped it out with all three extras that I have and none of them had any power when I plugged them in.??
Resets usually first start showing during Litz because of the power drain with everything running at once. 5 volt is getting weak for one reason or another. Can be z connections, bridge rectifiers, and a number of other issues. Check pin-wiki for resets. Has a great tutorial for finding the issue. Kahr makes a fix that eliminates the reset issue, without fixing the problem.
http://kahr.us
#1320 8 years ago
Does anyone know how the backboard is connected to the playfield ?
My first inpression was 4 screws, through playfield.
Removed those but it still won't budge ...... perhaps attached with something below the plastics or wooden dremmels?
#1321 8 years ago
Quoted from Imeh:
http://kahr.us
Ordered this the other day, just waiting for it to get here. Hopefully I wont have any more issues.
#1322 8 years ago
Quoted from Imeh:
The problem with this board is it takes the power from the 12 volt, and if you are on the edge of that you could start over loading that fuse. It fixed the reset problem on my CFTBL but it started blowing the upper GI fuse. I took the board out and just had the 5 volt rebuilt and all is good. I am not saying the board is not good because it is a great bandaid but it does not fix the problem.
#1323 8 years ago
Can somebody tell me why my TZ has 3 holes for the leg bolts on the front?
#1324 8 years ago
Quoted from Scout:
Wouldn't we all like to know!
#1325 8 years ago
Finally joined. This is mine, pre CPR mini playfield, slot mod, etc.
New clock:
#1326 8 years ago
Quoted from Scout:
Really?? Nobody knows?
#1327 8 years ago
Quoted from Scout:
I believe I heard once that it was thought the playfield had to be mounted in the cabinet at such an angle that to allow operators to get a better slope on the field, they could switch front holes to help increase pitch.
Sample games had three holes on front AND back - not sure if production cabinets kept that or not. AFAIK, noone makes the three-hole leg plates anymore.
#1328 8 years ago
Dupe. D'oh.
#1329 8 years ago
Quoted from Thor-NL:
You're right but there are 5 screws and not 4.
#1330 8 years ago
Quoted from scampcamp:
Pinsound.org is the best solution for improving the sound. A couple of great new sound mixes are availale on the community forum as well a an upgraded stereo original. Makes a hugh difference even with stock speakers.
#1331 8 years ago
Quoted from bdaley6509:
Nice! I love the spiral back wall and bright lighting. The two tone clock is an eye catcher too.
Need to do something to make mine unique, but fixing the clock is low on my long TZ project list, but the cool weather is coming, and I have ordered some parts, so it's high time to start. hehe
It seems every TZ that I play on location does not play very well, and I wondered if the TZ gameplay in Pinball Arcade was nothing like the real thing, but I recently played one that rocked, and I won a few free games. Now I know that TZ can kick ass in real life, and imagine once my project is done, I am going to be a happy camper.
#1332 8 years ago
Twilight Zone - "The most abused title with mods in the history of pinball".
Other than that, I can only say good things about it. I have owned mine since 1994.
#1333 8 years ago
Quoted from Scout:
This allowed operators to further lower the legs and change the angle so children could play the game. Both the the front and back legs have three holes, as early part of the production kept the sample cabinet design. Final part of the run had two hole leg plates
#1334 8 years ago
Quoted from Scout:
Read above, i asked this same question in 1994 to the distributor, when I bought mine, along with what I knew from the operator I worked for at the time, the answer "jived". There are OTHER games games that used the three hole cabinet design, mostly from the 1992-1993 period. I have a BSD for example that uses the same cabinet style, and couple of others that were early production runs.
#1335 8 years ago
Quoted from xTheBlackKnightx:
I just don't dig all those TZ mods: slot machine, rocketship, camera, robot, talky tina, etc, etc, etc.... they all get in the way of the ball view....
#1336 8 years ago
Quoted from AlexSMendes:
I'm partial to mods and understand that some people don't like them, but I don't follow how they get in the way of ball view. Many of the mods actually highlight what to shoot for. For example, the invader is tied into the extra ball insert, robot ties into mb ready insert, camera to camera insert and the slot machine is just flat out cool, spinning when the ball passes through, for example.
Here's a pic of my modded out game, not much distraction really, everything is easily visible. T bird obscures pops a little, but it can be repositioned off to the side. Never have I lost track of the ball because a mod blocks the view. In some games, inserts are blocked (avenger in lanes for example) and a mod makes them either easier to see or easier to know when they are or aren't lit.
Pinball is all about lights, bells and whistles, things that enhance that are good.
#1337 8 years ago
Quoted from lb1:
You are absolutly right!!
5 screws instead of 4 for the backboard attachment on a TZ.
Tucked away under the gumball diverter mech
Thanks for the help !!
#1338 8 years ago
Anyone know what type/size screw (and washers, if any) should be used on the habitrail leading to the powerfield? (It's affixed to a post that's between the left orbit and left ramp). Couldn't find it in the manual.
#1339 8 years ago
Quoted from ryanwanger:
Anyone know what type/size screw (and washers, if any) should be used on the habitrail leading to the powerfield? (It's affixes to a post that's between the left orbit and left ramp). Couldn't find it in the manual.
Believe it's the same as all the other posts - #6-32. (Maybe #6-40? Can't remember at the moment!)
#1340 8 years ago
If you drop a pic I can easily check tonight since I have my playfield out.
#1341 8 years ago
Quoted from lb1:
It's the screw that screws into the orange post in the lower right of this pic.
#1342 8 years ago
I will check later - if someone's not already responded.
#1343 8 years ago
Quoted from lb1:
#6-32. I used a washer that is a bit larger than the screw so it covers the habitrail attachment.
#1344 8 years ago
My apron has what I thought were scratches in the light blue area around the "TWILIGHT ZONE". I was comtemplating ways to touch them up, and then clear coat the whole thing. Then I am looking at Chris Hutchins' gallery (i.e. http://christopherhutchins.com/gallery/album620/33_G?full=1) and I am also seeing some tiny dots. What's the story? Do all aprons have these from the factory?
#1345 8 years ago
"And the ridiculous mods just keep right on coming..."
The backboard decal for those that are not aware with the "spiral" or "series version" does look GOOD, like it came from the factory.
There were a couple of different ones, and these were Treasure Coves.
Mine is quite different from the photos here, and I have no memory of where it came from, as the spiral is MUCH MUCH bigger and on the other side and matches the playfield art perfectly.
I installed at least a decade ago, probably more.
The decals on the lamp post and diverter DO NOT look good.
Take no personal offense, I just don't like some of the things that have been made on the market.
I can deal with the LED thing, as in many cases, it actually reduces stress on the electric circuits, adds better color to the playfield, reduces the number of times you have to replace bulbs, and reduces potential heat damage, especially for plastics, GI tract lighting, and boards.
If the market was not flooded with junk, and more people spent extra time making more proper reproduction parts, we would be singing ultimate praises, instead of being on the "eternal hunt". I remember looking for a WH20 part for my machine for 2 months, and was saved by a fellow collector friend, instead of going to a machine shop. Plenty of other examples as well.
#1346 8 years ago
here is one repro part I did a while back for BoP and TZ available at Shapeways
https://www.shapeways.com/product/E2ES3LJ4Z/pinball-drive-wheel-03-8476-tz-bop?optionId=55148175
#1347 8 years ago
Quoted from swinks:
Gotta love rapid prototyping as a mechanical engineer.
God, I wish this had been available 15+ years ago.
Great job!
#1348 8 years ago
I personally don't like most of the TZ mods, but it's all personal preference.
Want to bling out your game? Go for it. Want to keep it mostly stock? Sure, it's your game.
I like LEDs in TZ for the reasons mentioned, but don't really like them in my IJ. I do like the plastic or glass gumballs, door flashers, and some type of sprial sign as these should have been on the game to start with. At least from what I have been told.
I like the diverter and lamp post decals, and a less busy backboard decal too. What I wish would be developed is a lamp post that doesn't show the wires or use zip ties.
#1349 8 years ago
Quoted from TrainH2o:
FWIW, I never notice the wires on my lamp post, but I understand your concern.
#1350 8 years ago
New Load Gumball from LeesParts.com. Light up your right orbit with a red glow when load gumball machine is active. Looks great when used with PinBits Gumball Machine Light.
http://www.leesparts.com/products/twilightzone-loadgumball-light.html
$ 43.99
Lee's Parts
€ 75.00
PPmods
$ 24.00
Various Novelties
Pinball Photos LLC
$ 110.00
pinballmod
$ 115.00
pinballmod
$ 62.00
$ 115.00
pinballmod
$ 12.95
$ 129.50
8,800
Uniontown, OH
$ 12.95
8,500 (Firm)
Milwaukee, WI
$ 14.95
Pinball Pimp
$ 115.00
pinballmod
10,500 (Firm)
Brooklyn Park, MN
9,500 (OBO)
Martinez, CA
$ 49.99
Mitchell Lighting
$ 79.50
$ 24.00
Various Novelties
Pinball Photos LLC
$ 21.99
Lee's Parts
$ 399.00
$ 6.00
Arcade Upkeep
$ 145.00
$ 15.45
KAHR.US Circuits
$ 63.00
This page was printed from https://pinside.com/pinball/forum/topic/twilight-zone-owners-club/page/27 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
