Quoted from Luppin:I read it is possibile to install 7 balls (6 + Powerball). Is it enough to add a sixth regular ball, or is it also needed a recent eprom?
I guess it is needed to set the number of balls in the Gumball to 4, right?
Also, the software sometimes "emulate" the powerball if the real powerball is not showing up after a certain amount of plays: 7 balls can create problems?
Technically, no adjustment is needed, no newer ROM is needed. The game was originally designed for 7 balls - 6 regular, 1 powerball. My machine still had the decal on it that says that, even. (It was dirty and scraped up, I had new ones made..) You can set the gumball adjustment to 4 balls, but I do not know if it will 'simulate' the powerball every 4 balls or not. Honestyl, the adjustment does not do much, as the game will load up balls into the gumball until there are only three in the trough, so you could have 2 or even 5 balls in the gumball, the game doesn't really keep track.
The game dropped a ball due to that amount of balls making LITZ a little too difficult with the jackpot shots and powerfield, as far as I heard.
Once balls go into my game agian, I plan on making it 7.
--Me
