Quoted from Invader:I haven't got a reply yet also. Ingo, could you please also check my mail / PM? Thanks.
Sorry, will do tomorrow morning ... promised!!!!
Hello, planning to buy a tz. A seller is telling me his tz is working fine, but sometimes he gets an error regarding the clock, although the clock works fine during play. He says he previously has another tz, behaving in the same way. So it looks like its a Tz thing to sometimes show those errors. Is this true? Or should I be concerned about those error messages?
Mine tells me there is a gumball switch error but the gumball machine works as it should every time.
Quoted from pauloz:Mine tells me there is a gumball switch error but the gumball machine works as it should every time.
Which switch? Exit? Entry? Popper?
Quoted from Luppin:Hello, planning to buy a tz. A seller is telling me his tz is working fine, but sometimes he gets an error regarding the clock, although the clock works fine during play. He says he previously has another tz, behaving in the same way. So it looks like its a Tz thing to sometimes show those errors. Is this true? Or should I be concerned about those error messages?
Very common problem. The best thing to do is get a new clock board Ingo in Germany. His boards are easy to install and work well
Quoted from pauloz:Says 55 gumball Geneva.
Ah yes -
Then what's happening is that the game is compensating for it - instead of stopping the motor when the Geneva switch is activated, it's stopping when the Gumball Exit switch is activated.
I would get it fixed, as if your Gumball Exit switch misses a ball one time, or goes bad, then you'll get multiple balls out on your playfield unintentionally.
Quoted from Coyote:Ah yes -
Thanks for that. Will get it sorted.
For the record - The "-SP" designation on plastics does NOT mean it's a "sample plastic". The -SP came from the printer of the plastics. (Sun printing, I think? I'm not 100% on the name.)
The only difference was artwork changed, and this did not constitute new part-numbers on the plastics.
Quoted from dmacy:Sun Process but I may be wrong as well Coyote!
Ah! That rings a bell, yup! (I had to rant because of an auction I saw, and had to clarify for anyone considering purchase..)
Something I've not seen before is all 4 corners were drilled with 3 holes for leg bolts. In fact all mounting plates were 3 hole versions. Was that common on games?
Quoted from Sethman:Something I've not seen before is all 4 corners were drilled with 3 holes for leg bolts. In fact all mounting plates were 3 hole versions. Was that common on games?
Not sure about other games, but TZs had this standard. The 3-hold plates aren't made anymore (that I know of?) so when I replaced mine I had to line the holes up with the new plates before screwing them in.
Quoted from Coyote:Not sure about other games, but TZs had this standard. The 3-hold plates aren't made anymore (that I know of?) so when I replaced mine I had to line the holes up with the new plates before screwing them in.
good to know, Thanks. Same for me, had to replace one just now with a 2 hole plate and lined up with the bottom 2.
I printed and lasercut some stickers for my coindoor
Check it out:
I have some left, if someone is interested (€7,50), please send me a PM:
Sticker is 3 layers, white backing paper, white TZ letters and clear front film:
Remove white backing paper:
Apply to the coin door (or anywhere else):
Quoted from Invader:I printed and lasercut some stickers for my coindoor
Are these available? That looks good.
Hello,
Joined the club! So happy to finally get this legend!
A question for the experts: my TZ came with manuals and documentation(see pics). From their conditions, they really look (and smell) like 20+ years old, not reproductions or copies. Especially regarding the manual, I saw online that the cover should be red, while mine is white (carton cover, as a normal w/b manual). On the cover there is no logo or graphics, the date is february 1993 instead of april, and the code is 16-50020A-101 instead of 16-50020-101. The pin has an original white clock, but not a proto, so I am thinking this could be an early production one.
What you think?
According to this page, you own a rare pre-production TZ manual!
http://pinballgold.com.br/?product=manual-twilight-zone-bally-raridade-16-50020a-101
That's a sample manual, yes. Not all that rare, as hundreds went out before the April version was typesetted and printed and then put into games.
You will see some notable differences, though, including the 4 door flashers, and removed optos.
Quoted from Luppin:Like brand new!
I surely hope... You see, like you all I'm also seeing the machine only by photos... It is being restored in Sao Paulo, approximately 500 km from home!
Quoted from Luppin:hi, I checked my TZ software. It says revision L-5 and sound revision P-3. Are those revisions enough advanced? where to find the revisions list for TZ?
I do think the latest game version is 9.4H for home use (free play). As for the sound rom P-3 would be the last.
Question about the ball kickout after the ball is locked--I'm speaking of the ball lock just behind the clock in the upper right of the PF. Beneath the PF, is there supposed to be a spring wrapped around the coil plunger (as on, say, sling coils)? Mine has no such spring, so I'm wondering if other TZs have the spring and mine has just broken off. It's a gentle sideways kickout so maybe there is no spring, but my plunger is having some trouble retracting even after a cleaning, so I'm thinking of adding a spring. Could someone confirm that their TZ does or does not have the spring?
Quoted from JOESCHALL:Question about the ball kickout after the ball is locked--I'm speaking of the ball lock just behind the clock in the upper right of the PF. Beneath the PF, is there supposed to be a spring wrapped around the coil plunger (as on, say, sling coils)? Mine has no such spring, so I'm wondering if other TZs have the spring and mine has just broken off. It's a gentle sideways kickout so maybe there is no spring, but my plunger is having some trouble retracting even after a cleaning, so I'm thinking of adding a spring. Could someone confirm that their TZ does or does not have the spring?
Yes, there's a spring there. It's a very light one, but it's there none-the-less.
Quoted from Coyote:Yes, there's a spring there. It's a very light one, but it's there none-the-less.
Thanks for the quick reply. I'll add one!
Quoted from AlexSMendes:I do think the latest game version is 9.4H for home use (free play). As for the sound rom P-3 would be the last.
Font: http://www.ipdb.org/machine.cgi?id=2684
I cannot see L-5 in this list... ??
Also, the Romset list is in alphabetical order, so I cannot figure out how recent is my revision.
Any help?
Quoted from Luppin:I cannot see L-5 in this list... ??
Any help?
Take a look at some ebay listings.... usually the chips for sale have the latest versions.
http://www.planetarypinball.com/mm5/Williams/tech/roms/twilight.html
Has listing of the rom revisions. I see no mention of L-5 anywhere as an official release, odd
Mine is still on L-1 and about to put in 9.2 tonight
Any help?
For the early ROMs, P was sample/prototype code, L was release code. Then the numbers - i.e. P-1, P-2, P-3, L-1, L-2, L-3, and so on.
Once TZ was moved over to the new version of the OS, they moved to the new numbering, 9.2, 9.4H..
My official notes don't have L-5 listed either. If you want, I can send you a version of your choosing, if you send me your chip - would like to grab a copy and see what (if anything) is changed in it. .. Of course, mailing time may be slow.
Any help?
If you just want to know how recent it is check here: http://www.actionpinball.com/parts.php?item=ROMS369
But there's no changelog entry for L-5, nowhere. Doesn't really matter as you'll want the latest home version with pause function and the LITZ-cheat anyway. You can run it on coins or free play. (http://www.actionpinball.com/tech/tz94h.php)
Thanks! It makes sense now. L-5 should be the latest version for location. Do you think its worthed taking the home revision or not?
Quoted from Luppin:Thanks! I can see L-5 in this list. But what is a changelog entry? What do you mean?
Non c'e di che!
I mean the list where you can see what exactly was changed since the last version.
Quoted from Luppin:Thanks! It makes sense now. L-5 should be the latest version for location. Do you think its worthed taking the home revision or not?
Actually, 9.2 is last on-location version.
This page was printed from https://pinside.com/pinball/forum/topic/twilight-zone-owners-club/page/21 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
