Quoted from ryanwanger:What I meant is that the left one is entirely different. It should say: "Defeat the power by shooting the ball thru top of pyramid". Like this: http://www.marcospecialties.com/pinball-parts/A-16416-2
I must have spaced out when I ordered it. Funnier thing is that I didn't even notice it. Anyone need a brand new manga flip sign?
Quoted from Lermods:I must have spaced out when I ordered it. Funnier thing is that I didn't even notice it. Anyone need a brand new manga flip sign?
The sad part is that I just bought one last week and installed it. That's why I noticed!
Quoted from Coyote:What the hell is up with the apron?
Check: http://www.pinballdecals.com/PartsByGamePages/TZ_Page.html#
Man, I simply do not get the current mod-crazy pinball culture. Guess I'm just a purist...or just old.
Quoted from JohnnyHK:Man, I simply do not get the current mod-crazy pinball culture. Guess I'm just a purist...or just old.
Sometimes less is more! I defnitely feel that when it comes to the TZ.
a little of both
I enjoy blinging some things but then also enjoy leaving others completely stock.
Those guys have some pretty outrageous prices.
I like mods, pinball is all about bells and whistles. TZ is one of those games that seems made for mods, some are better than others. Personal taste.
Quoted from Lermods:Those guys have some pretty outrageous prices.
I think that's the case with all the mod sellers....
Anyway, Pinball Decals' quality are very good, and Joey is an extremely nice pinball fellow!
I don't like to pimp out the game too much because I like the original look. I do believe however that the gumballs, magnet diverter, and piano is a must. Other than that, it can be a little overbearing but to each it's own.
Edit: Life is short. Using screws. Want to play the game already. Just found out I'm out of 1-1/4" white rubbers. Life is pain.
Has anyone ever riveted the TZ signs back onto the Great Lakes Modular switch kit? I bought a Pinrestore press for the job only to learn that I had wasted $200 because the PCB is vertically in the way of the hole so there's very little clearance for a tool to press the back of the rivet. The website shows screws in the example picture so I guess he didn't do it properly either.
Will one of those squeeze type tools work? It looks like no, because I would need the faces reversed to fit.
These stupid rivets have been holding me up from finishing my mini playfield for weeks now
Quoted from DefaultGen:Edit: Life is short. Using screws. Want to play the game already. Just found out I'm out of 1-1/4" white rubbers. Life is pain.
I used pop rivets on mine and they worked great. Just be sure to use aluminum rivets so you don't break the plastics.
Quoted from fiberdude120:I used pop rivets on mine and they worked great. Just be sure to use aluminum rivets so you don't break the plastics.
Thats what I did as well, works like a charm
20150506_095615.jpgQuoted from DefaultGen:Has anyone ever riveted the TZ signs back onto the Great Lakes Modular switch kit? I bought a Pinrestore press for the job only to learn that I had wasted $200 because the PCB is vertically in the way of the hole so there's very little clearance for a tool to press the back of the rivet. The website shows screws in the example picture so I guess he didn't do it properly either.
I used button head fasteners that I saw someone suggest somewhere. They look about the same as the pop rivets, but are removable. I have a few extra if you would like me to send you some (although you will have to wait a week since I am headed out the door to catch a plane now).
Quoted from SuperPinball:Both of my flippers on the right side of my TZ occasionally cut out. I looked but my game has no flipper optos and the coils look new. I'm starting to think its the fliptronic 2 board. Has anyone had a similar problem with their machine?
What rom you running? There is also a option for low line voltage which can cause them to cut out if its on .
I have the latest rom installed, I will look for the low line voltage, but wouldn't it affect both sides?Anyways I will check that, thanks.
Quoted from SuperPinball:I looked but my game has no flipper optos and the coils look new.
Did you mean to say "new flipper optos"? Or does yours have actual leaf switches?
Quoted from SuperPinball:I have the latest rom installed, I will look for the low line voltage, but wouldn't it affect both sides?Anyways I will check that, thanks.
I heard of different flippers being effected so not sure
Quoted from Miguel351:Did you mean to say "new flipper optos"? Or does yours have actual leaf switches?
The next time they fail, go into switch edge test and see if both of the leaf switches are even registering. Also, check the wires where they plug back into the main harness(if memory serves me correctly) to check to see if one of those wires is loose at all.
Gotta start at the easy stuff, which I'm good at!
Quoted from Miguel351:Gotta start at the easy stuff, which I'm good at!
sounds like good advice.
I had an issue with mine where the upper right flipper would flutter for seemingly no reason. Got a new fliptronics board and it solved the problem. I wonder if I can just stick that board with the flutter into a 2 flipper game without issues?
Quoted from ryanwanger:I wonder if I can just stick that board with the flutter into a 2 flipper game without issues?
Theoretically It seems plausible but Rottendog Fliptronic boards are only $75 so probably not worth the effort.
I had weak flipper issues and switched the boards at the lower flippers and it corrected the problem. Not sure why, but it did.
Quoted from Lermods:I had weak flipper issues and switched the boards at the lower flippers and it corrected the problem. Not sure why, but it did.
The Fliptronic II board or the Flipper opto boards?
I joined the club again yesterday for the 4th time... My TZ history goes like this:
1st game sold to PAPA - Destroyed in the flood
2nd game traded to a friend for 2 Rush the Rock driving games
3rd game traded for a Guns & Roses
Must be the Pinball God(s) telling me that I'm destined to own one! I traded my IMVE for this beauty! The cabinet, playfield, boards, etc.. are mint! Needs a good cleaning and rebuilt flippers, but that's about it!
Rob Bell
Robsgameroom.com
I have a different Piano mod from another pinside member who makes these and I had to unscrew the lights in order to get the Piano mod to fit. That's how it was designed. I'm sure it's probably the same with the mod you have as well.
Quoted from DefaultGen:No posts in 2 weeks in the best club, someone buy a CQ machine and post pics to drool over or something. I'm cleaning really dirty inserts, feels so good.
I can do that for you20140714_012054.jpg20140714_011536.jpg20140714_011356.jpg20140714_012203.jpg20140714_010146.jpg
Quoted from Coyote:Here's a pic, and a test for folks -
Can you find the one insert that's not correct, or has something wrong to it?
..It shouldn't be TOO hard.. And it's not the Lock - that's green.
Hard to see everything clearly, but the second word in the Dead End insert does not look like the word "End" to me.
Yea the pic is hard to really tell anything but the shoot again maybe?
I upgraded the powerfield with cold white LEDs under the star posts.
Added warm white LEDs behind the two signs.
GLM switches.
Clear lexan cover under the playfield
Blue LED under playfield that shines on the Hitchhiker guy.
Ehhh... and a some more things I forgot right now.
Replaced translite glass with bestofpinball anti-glare sheet, behind a next gen translite and NoFlix LEDs.
Also a RGB LED strip behind Rod Sterling, it looks freakin awesome but could not get the awesomeness on the picture though.
One bummer of the the awesome translite is the extreme glare on the playfield glass
(got anti glare filter on the DMD btw)
Hmmm... how can I fix this Translite glare on my playfield glass?
Don't want to dim the light of the backbox...
Quoted from DefaultGen:Are the connectors supposed to stick way out of the Ingo board? I'm not sure if I have room to put in the PinballMod piano mod. Are there install instructions for that piano? I'm supposed to unscrew the bulb sockets, right?
New vs old:
Not sure which piano mod you have, but I have ingos board and a piano mod with no fit issues so it should work for you.
Quoted from ryanwanger:Hard to see everything clearly, but the second word in the Dead End insert does not look like the word "End" to me.
Quoted from bigd1979:Yea the pic is hard to really tell anything but the shoot again maybe?
Sorry for the pic quality - it was taken while the field was being cleared. I posted a better picture below, and you should see it *right* away. The 'End' looks like that because when this field was printed, the black was too thick - it's a lot thicker than other playfields I've seen. Some finer/smaller letters are kind of run-together.
Quoted from DavidPinballWizz:After owning the machine for 17 years.. i finally installed the gumball flashers in the doorpanel
Quoted from Invader:Blue LED under playfield that shines on the Hitchhiker guy.
I'm NOT a big LED guy, and like colored GI's even less.
However, I DO like how the hitchiker is lit up, and could seriously consider that. What LED did you use there?
Quoted from Coyote:I'm NOT a big LED guy, and like colored GI's even less.
I've used this LED:
http://www.pinballcenter.eu/catalog/t10-noflix-plus-blue-superflux-p-399.html?language=english
LED is soldered on two extended wires, so you can bend it the way you like
Quoted from Coyote:Spiral is missing!
Yup. Hah, said it was easy. Back when the game was delivered to our Arcade, the insert still had 'Gumball' on it. The tech that WMS sent down to get readings and make changes scraped the 'Gumball' off, and then realized he forgot the 'Spiral' decal to install. He asked me if he could mail it to us, and said that we could put it on.
We never got it, so I left the insert blank. When the game finally made it to my home, I figured it was a neat enough piece of history that when HEP worked on the playfield (that picture there is from him), I asked him to leave it blank, but clearcoat over it to protect it. (Before, since it was scraped off, it was rough..)
defaultgen-
did you figure out a solution to making the piano mod fit? I also have the "Laretrotienda" piano and the Ingo clock board... Thinking of maybe taking a dremel tool to carve some of the back out..
Quoted from Bowlingpin:defaultgen-
I also got the Ingo board and the Laretrotienda piano
It doesn't fit perfectly without modification.
There's a gap between the clock (in front of the right bottom screw) and the top of the piano.
It's stays firm enough under the clock though, so I left it this way.
This page was printed from https://pinside.com/pinball/forum/topic/twilight-zone-owners-club/page/18 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
