ok i have checked the continuity to every connector with my multimeter in column 8 (except left spiral, it is not listed on the diagram and i cant figure out what lamp it is referring to) everything reads perfect continuity. i have also checked continuity to every lamp in that row and get perfect continuity. I am getting some current through the lamp (see attached video) but not enough to light the bulb. i switched the bulb with the start button light and it works fine on the start button. i bypassed the outlet and connected the bulb directly to the two wires and still get low current flow. i measure the voltage at around 1.5 volts in the outlet which is the same as the start button.
Uggh this is driving me crazy, every other light in the colum and the row works fine (except left spiral because i dont know where that it) any suggestions will be greatly appreciated!!
