Quoted from jawjaw:Congrats. TZ is an awesome game. Just got mine not long ago. I also had issues with the clock optos. Instead of wasting time on the old boards, I bought the new Ingo clock board that is engineered better so should never have a problem again. Easy swap and new board has swappable leds.
Turns out I've already got the Ingo board in there. I took the front plastic off and found that the arms axle has a lot of play front to back. Maybe 1/8" or so. Is that normal? I wasn't up for tearing it down more, so instead I wiggled the optos "out" a little way so they're closer to the arm. After that, all the minutes register properly with the clock in the normal position.
And for the first time since I've had the machine, no credit dot!
Quoted from jawjaw:Coils firing like that are usually the result of a faulty switch - probably an opto. Open the game menu and go into the switch test. Hand press every switch and break the beam on every opto in the game. You should see that switch and only that switch trip on the display. If a switch triggers multiple switches then there is a short issue. Also bang around the playfield and see if any opto's trigger off of vibrations. For a complete list of switches, look for the switch matrix in the manual.
Good suggestion, I'll try applying some percussive motivation while in edge test to see if any switches or optos register.
Another thing that's been happening is occasional airballs when the ball hits the target right next to the slot machine scoop. Sometimes really bad airballs, like off the glass, over the sling and landing in the left outlane. I already tried bending the target forward but that didn't help. Do I need to replace the foam stuff behind it?
