Hi Pinside,
This is my first post. I recently bought a really nice, fully restored TZ machine. It worked perfectly, with daily use by myself and my son, for about six months, and now it doesn't feed the ball in to begin the game.
Test report shows:
check switch 26 trough proximity
check switch 36 left outlane
check switch 46 mini p.f. right (2)
check switch 56 gumball exit
check switch 66 mid. r. 5 mil. 1
gnd. short row 6 wht-blue r6
I understand this probably has something to do with the row 6 switches, but despite my best efforts with the manual, I've been unable to locate said switches for the visual inspection. Where are they? What should they look like? My guess is they are somewhere up behind the backbox, and possibly near the area where it says J207?
I'm fairly hopeless on the ohm meter, although I do have a working one in my possession. I'm not averse to purchasing a soldering gun and learning to use it, too. If the easiest fix is getting a new cpu board, that would be fine as well.
Any help, words of wisdom, hints, or clues would be much appreciated. Looking to get back into the zone...
With thanks,
Optoboy
