I am having an issue with my TZ where the opto switches on the top and bottom of the mini playfield are not registering. The rest of the switches in that column do register. I tested continuity from each wire on each transmitter and receiver back to the playfield harness and it is good. Also, when a ball it shot up the right ramp, the diverter will grab it and drop it onto the playfield, then a few seconds later the diverter will fire again with no ball on the ramp. Not sure if that is related but hopefully it is. Any guidance on where to go from here would be appreciated. Thank you!
