Good afternoon everyone. I'm new to the forum but have gotten many good ideas and info from here.
My TZ sat in storage for 4 years and I've now finally put it in my office. It always had the usual issues with the clock and miscellaneous switches/optos but I finally decided to get it back to pristine condition. Batteries only had minor corrosion so I cleaned the terminal and installed new batteries. I replaced the clock assembly with one from Marco. Fixed that problem. Replaced the opto sensors for both the upper and lower mini playfield. Now I have a problem that I can't figure out. I'm mechanically inclined but these machines are not in my wheelhouse. When the ball enters the mini playfield, it's fine until it engages the right side kicker and it immediately triggers the playfield exit. Mini playfield magnets stop working, ball drops out the bottom and regular flippers re-engage. I've done the switch edge test. If I block the lower playfield opto, it triggers switch #76 on the display. If I press on the right side kicker, it displays #46 and #76 very quickly. I've removed the mini playfield and checked for shorting or chafed wires. All appear ok. I've traced the wiring for the kicker and the optos and found no issues. I've pulled and checked all connectors both at the opto board and the CPU board. All appear ok and are firmly pressed in with no loose pins. I've removed the CPU board and checked for corrosion or tracing. All clean. I've searched the internet with no luck finding someone experiencing the same issue.
Here's my problem. I don't know if the problem occurred from sitting in storage or if it's related to my repairs. Any help would be truly appreciated.
