My TZ recently has lost the left side lamps in the center panel. No lighting in game or in test. I have checked the header pins and dont see anything obvious. Reseating and wiggling doesnt make a difference. I am terrible at understanding if there may be a fuse that controls this that has blown. The fuse list isnt clear as to which fuse and they appear fine from a general look, but before I go rooting around perhaps someone can chime in on whether there are separate fuses for the left and right side of the panel. The right side and the lock and gumball lamps ( center lamps) work as they should.??
Thanks in advance.
