New! Dark mode!
(Topic ID: 275898)
Twilight Zone Gumball Machine Malfuntion??
By qbass187
56 days ago
  • 9 posts
  • 4 Pinsiders participating
  • Latest reply 55 days ago by RonH
#1 56 days ago
Hey guys,
I noticed the Gumball machine on my TZ all of a sudden stopped working. It will not dispense the balls. Everything else seems in order. All switches work and register in switch test. When I try to get it to run in Test mode I get "Geneva Switch Malfunction" after about 15 seconds. No motor hum or anything.
The Geneva Switch registers in Switch Edge tests so I'm kinda at a loss here...
#2 56 days ago
Geneva switch isn’t activating at the proper time during gameplay, it’s a pain but needs to be adjusted.
#3 56 days ago
Quoted from jchristian11:
How would one do something like that?
#4 56 days ago
If you get no motor-whir in test mode BEFORE the error, that means that your motor isn't running.
Check the motor and the motor control board, make sure everything there is plugged in, has power, etc.
#5 56 days ago
Quoted from Coyote:
I checked the connections at the motorboard under the PF and reseated all the connections initially. Nothing changed.
I'm wondering if the motor just died... any way to check ?
#6 56 days ago
Did you check fuse F111, on my machine the motor was not running as well. I found out the F111 is connected to the flashers and gumball motor. My fuse was blown by a broken led flasher, thus leading to the gumball motor and Geneva switch error...
#7 56 days ago
Quoted from RonH:
I’ll take a look! Thanks
#8 56 days ago
Quoted from RonH:
BINGO!!!!
Ron, you’re the man!
That did the trick. Thanks everyone for all your help!
#9 55 days ago
Quoted from qbass187:
BINGO!!!!
You're welcome !
$ 259.95
Pin Stadium Pinball Mods
