I get a "almost every time" ground short row 1 is stuck closed message when turning on my newly acquired Twilight Zone. I've searched other posts and have checked all the switches that are easily accessible in row 1 looking for a short. I also checked fuse F115. I tried unplugging J208 and still got the message.
I'm suspecting U18 on the MPU board. But would like a second opinion before I start board work.
Other interesting facts -
MPU board is original and when inspecting it the only repair I could see was moving the batteries off the board.
I've lost a ball somewhere in the machine. I'm guessing its stuck somewhere under the playfield.
While looking for balls, I opened up the plastic under playfield ramp for the gumball machine. Managed to get 3 balls out of it and already had removed two other balls that were under the apron. After doing this, for one reboot and only one reboot the gnd short message went away.
When I turn the machine on, prior to the error message the machine continually tries to launch a ball from the auto-fire kicker, continually moves the shooter diverter and the clock dial moves.
Thanks for the help!!
Allen
