I just got a <400 play HUO TZ that has handed me several issues despite functioning normally in situ during the pre-purchase inspection. I’m asking for help troubleshooting the below issues, all of which I'm hoping have a common cause.
- Flashlamp voltage (TP7) shows 1.2V (even when powered off for several hours), jumps to ~30V when flasher bulb #28 is plugged in.
- Flasher #28 (inside ramp flasher) remains continuously on when an LED flasher is plugged in and will remain dimly lit after turning off the machine.
- All other flash lamps function normally when flasher #28 is plugged-in and will turn off within about 10 seconds when #28 is unplugged.
- Incandescent flashers plugged into #28 do not illuminate, however they will turn on/off all other flash lamps, as described above.
- The mini-playfield magnetic flippers no longer work during game play or tests.
- Gumball geneva mechanism no longer works during game play or tests. Applying voltage to the motor lugs causes motor to spin the mechanism.
Power Driver Board Test Results:
All 6 LEDs on the board lit.
Unregulated 12V (TP1): 14.4
Regulated 5V (TP2): 4.8
Regulated 12V (TP3): 11.9
Zero-Cross 0.4V (TP4): 0.4
Coil power 70V (TP6): 77.4V (fluctuates between 69 – 89)
Flash Lamps 20V (TP7): 1.2 (30V when FL#28 plugged in)
18V (TP8): 18.1
All fuses pass continuity check.
Any help is greatly appreciated!
