Finally got my clock working properly...it wasn;t working correctly to begin with so I had no idea what I was working with...
Replaced the board with Ingo's
Picked up a new Blue Bezel and clear front
Installed Ingos board and put everything back exactly (I thought) together.
Well for some reason with the new bezel, reinstalling the screws on the front and back were very tight. I reinstalled the clock and was getting an intermittent clock broken message, it work sometimes and sometimes it wouldn't. I had started to think it was in the wiring. So instead of ordering parts, I decided to remove the clock and go through it step by step. What it appears is when I reinstalled the screws on the bezel of the clock, they felt very tight going in, but actually left room for the number's face to float enough to mess up the opto that was picking up the hour. Once everything was tight she was working perfectly, except.....
When the clock would zero out at 12:00 on start up, the hour hand was in the 11:30 postion and the minute hand was in the 12:00 postion. What I think happened was at one point someone worked on this clock and put the minute hand in upside down. I flipped it over and now both are dead on at 12:00
Two thumbs up for Ingo's board, and I am extreamly releaved to have this issue resolved. I am proud to say she has no credit dot.
