New! Dark mode!
(Topic ID: 110665)
TWDLE GI going out intermittently
By underlord
5 years ago
  • 10 posts
  • 8 Pinsiders participating
  • Latest reply 5 years ago by gweempose
#1 5 years ago
Anyone had this issue yet? Before I call Stern, just wanted to get feedback here. Checked all the usual suspects. Connectors, fuses, etc.
#2 5 years ago
Your inside buddy should know.
#3 5 years ago
Mine was doing that. Seemed like it needed to be warmed up or something. I fiddled with all of the connections laying in the bottom of the cabinet and it stopped. Not sure what it was. Someone told me to check those connections. So far so good.
#4 5 years ago
Quoted from TomGWI:
He's definitely no Patrick Powers.
#5 5 years ago
when you call them up underlord, Ask them how far away the code is BTW
#6 5 years ago
https://pinside.com/pinball/forum/topic/software-issue-with-wdle#post-2053348
Someone here said it was a software issue but I would certainly call.
#7 5 years ago
Haven't had that issue , but have had playfield led sockets not plugged in or half hanging out, found a fuse that had only one side clipped in , and my diagnostics loom wasn't firmly connected , it didn't work at all , only to find it needed a more snug connection , have bought mine NIB PRO
#8 5 years ago
Going in and out sounds like a ground problem. I would check all the ground wires in the lamp matrix. Sounds like a ground may not be punched down completely in one of the molex connectors in the back box. Happened on my MET.
#9 5 years ago
The le twd version in town does that. Owner said it was a code issue.
#10 5 years ago
Quoted from Droptargets:
My LE doesn't do it. I assume we are running the same version of the code.
$ 279.95
Pin Stadium Pinball Mods
$ 19.95
$ 8.95
