So my TWDLE started firing the 1st drop target, on the bank of 3 on left side (closest to the flippers) In tech alert says check switch #60? Any ideas as to what is causing this??
Switch #60 is right spinner so i'll have to look into that further. When I do a coil test only the 1st target drops, not sure if that's normal or not?
