Quoted from beatmaster:no problems with the board all of them have 5 and 12 volts, depending on how it's wired in the plug, it's 12 or 5 volts.
Thank you for the clarification Beatmaster.
@ Quartergrabber: I'm a newb so take what I say with a grain of salt. TWLE is my first pin. Here is what I understand. Someone will correct me I hope if I'm wrong.
You can plug any of your mods into any port on the board like you have done. If you look at the wires going into each molex connector it depends on where the wires are spaced in each connection as to what they need to pull 5v or 12v. My bicycle mod has the 2 wires spaced right next to each other and I believe that pulls 5v. I'm guessing if a molex connector has the wires space on the ends with the middle empty that is pulling 12v. (I think, maybe)
So if what Beatmaster is saying is true it doesn't matter what you plug your molex connectors into on the board as they will pull the proper voltage each connection needs dependent on how the wired pins are spaced in each connector. The board confuses me because it has the 2 LED green lights one labeled for 5v and the other 12v. You would think by looking at it the top row is 5v and bottom 12v. Reading on dkpinballs sight didn't help me. If you want to really find out instead of taking a newb's word you should PM: dkpinball. (then let me know too)
So you only need to worry about your pinballbulbs light kit with the 2 LED strips and all your other electrical mods as a total not exceeding the total voltage capacity of the coin door power connection you tapped into. Don't ask me, that's another thing I've tried to search the answer to. I'm under the impression its like 2.? amps. You should probably start a thread in the tech section to pursue that so we can leave Nody's thread alone. But hey, these posts did count for bumps!
