Woodbury is about the skill of just hitting the second rollover after you select it.
At least that's what I shoot for
Quoted from Pdxmonkey:Woodbury is about the skill of just hitting the second rollover after you select it.
Different rewards have different spots you need to get the ball to
I'm a moron. I didn't even realize you could use the flipper buttons to select the Woodbury award. That's why I thought it kept offering me the same reward every time.
Now that I understand it, I think it's a really damn cool feature.
Quoted from gweempose:I'm a moron. I didn't even realize you could use the flipper buttons to select the Woodbury award. That's why I thought it kept offering me the same reward every time.
Thank you for the laugh
Correct, I typically go for the 1,000,000 award.
Has anyone else had a strong R ramp shot -- typically combo'd from a Tunnel shot on the fly -- only to have it jump off the R ramp onto the L ramp's return trail (on the right side) but still have enough speed to make it around the L ramp trail in reverse, eventually coming down the left ramp at top speed ... SDTM?
Quoted from Snailman:Has anyone else had a strong R ramp shot -- typically combo'd from a Tunnel shot on the fly -- only to have it jump off the R ramp onto the L ramp's return trail (on the right side) but still have enough speed to make it around the L ramp trail in reverse, eventually coming down the left ramp at top speed ... SDTM?
It sounds like the exact same thing happened to Darkwing ...
Quoted from Darkwing:Did a triple combo shot today and on the third loop it jumped from the right ramp to the outside ramp, came back around and down the CDC ramp SDTM... Too much combo!?!
I had something similar happen. I shot the right orbit, then solidly nailed the right ramp on the fly. After the ball came around behind the playfield, it flew off the ramp and got stuck behind the left flasher dome. I think the game needs some strategically placed plastics that cover the ramp and prevent these sorts of things from happening.
Every once in a while, my well walker will get stuck in the leaning back position. Does this ever happen to anyone else? Any ideas how to prevent this?
Quoted from gweempose:Every once in a while, my well walker will get stuck in the leaning back position. Does this ever happen to anyone else? Any ideas how to prevent this?
We have over 300 games on ours so far and this has never happened.
If this happens again, Check well walkers hand is not caught behind the crossbow/fish tank sign, I had to adjust the metal bracket, be very careful the bracket is part of the plastic ramp
Quoted from skywalker:If this happens again, Check well walkers hand is not caught behind the crossbow/fish tank sign, I had to adjust the metal bracket, be very careful the bracket is part of the plastic ramp
I had it happen again, and you were absolutely correct. The tip of the well walker's finger got caught behind the sign. Looks like I'll have to slightly bend the bracket.
Be careful not to stress the plastic, used 2 hand held pliers, combination pliers to hold the vertical bracket & long nose pliers to tweek the top up
Quoted from skywalker:Once you go the update code 1.11 that error will go, the update is waiting
Mine came with 1.11 out of the box and I have a switch 60 error. I was wondering if switch 60 is the skill shot? Since I haven't ever been able to hit it?
Quoted from n0s4atu:Mine came with 1.11 out of the box and I have a switch 60 error. I was wondering if switch 60 is the skill shot? Since I haven't ever been able to hit it?
Think the LE's came with updated code Version compared to a pro, my pro had that error #60 tried to look into it with no luck, updated code & it was gone, someone else may have more info or wait for the next update
Has been some discussion about the Tower target plunge shot/skill shot, this target can be pretty hard to hit on the plunge, Maybe is meant to be this way
Looks like the target could be moved across very slightly, Had a look under the PF not much adjustment there unless you open up the mounting holes a bit, have a look at your target position & post up what you see
I was finally able to get the skill shot after some practice letting the plunger go at just less than 100%. But if you just give it full force every time it will not hit.
Quoted from Darkwing:I was finally able to get the skill shot after some practice letting the plunger go at just less than 100%. But if you just give it full force every time it will not hit.
Has anyone gotten confirmation from Borg that this is by design?
Quoted from gweempose:Has anyone gotten confirmation from Borg that this is by design?
Well, if you got it every time by default (ala Space Jam), it wouldn't be much of a skill shot
This page was printed from https://pinside.com/pinball/forum/topic/twd-sdtm-or-other-issues/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
