(Topic ID: 109579)
TWD LE: Best Way To Adjust Outlane Posts?
By PinballZach
  • 12 posts
  • 8 Pinsiders participating
  • Latest reply 4 years ago by Hazoff
#1 4 years ago
My TWD LE arrived a few days ago and I love that it's a tough game but it really seems to like those outlane drains. The outlane posts are adjustable like all games but is only reachable on the right side through a small hole in the ramp, the left is blocked on the LE by the crossbow magnet ramp diverter. How should I proceed to move the outlane posts down to there lower position without taking the ramp off completely or am I stuck taking it apart?
-1
#2 4 years ago
Yes tough game, leave it a fact setting & work harder at it IMO
#3 4 years ago
Quoted from skywalker:
Yeah, I keep fighting with myself about whether I should leave them alone or not, I was hoping to move them down for a little while just to get some more practice on the shots then move them back up.
#4 4 years ago
Even with the slight adjustment made, minimal difference
#5 4 years ago
You have to move the ramps a little not remove just enough to move them enough,and like stated above it helps very little
#6 4 years ago
Yes you have to move ramps, but it only takes about 15 minutes, to get a little help with out lane
drains.
#7 4 years ago
Just put a thicker rubber on it. That's what she said.
#8 4 years ago
If you take out the lower 4 ramp screws on the left side, and the lower 2 ramp screws on the right side, the ramps will be able to move enough to remove the posts and put them in the lower holes. That is what I did anyway.
3 weeks later
#9 4 years ago
Any update? Also installation od standard posts instead of mini didn't help to avoid permanent draining much. Quite often it bumps directly from the left or right sling to the corresponding outlane without any chance to save the ball.
#10 4 years ago
I can't find them now but I bought thick white rubbers and changed the thin posts to star posts on my IM and it worked really well. I'll post the type once I allocate them. I'm going to do this on my TWDLE I think.
#11 4 years ago
That would be great. So after changing mini posts to star posts I need to install bigger rubbers to the star post than usually, hope this will work better.
#12 4 years ago
http://www.marcospecialties.com/pinball-parts/38-0012
Might have been just a 1/2 inch. I'll keep looking
€ 89.00
YOYOKOPTER MODS
Professor Pinball
$ 22.00
$ 129.95
Hookedonpinball.com
