I just received an LE and am in the process of de-modding it. I removed Bicycle Girl ramp airball protector last night because it was causing a series of issues that led to the ramp not seating properly and thus rejecting most shot attempts. Is this a factory stock item or indeed a mod? The install was wonky in that there was not post inside the upper rubber, only a long screw to go into the lower post. When the screw was tightened it compressed both post sleeves and created a wrinkle in the bottom one that the ramp would catch on and not seat properly. Should there be something inside to help provide rigidity? Also, the ramp lifts and hits the protector and therefore stops well short of the factory bumper stop. Since removing the protector and associated structure the ramp is makeable as normal. Thoughts? (note, the pic is not my machine, it's from the forum image library).
BTW - I will be selling all of the mods and posting them here.
