Quoted from Chalkey:As far as the DVD fish tank mod, is it independently lit or just lit through the GI on the backboard?
Not sure about the one above, on the post prior on my tank. The green is a constant lit effect but I have it on a dimmer to adjust the brightness, the blue led effect is tied into the topper's general illumination effect which fades in and out, then there are warm leds over each head and that is tied into the topper's individual head lighting sequence.
Quoted from DeathHimself:Do you have a 3D Printer? I made a bracket that holds the tank in place using the backboard screw and it's location that's already there.[quoted image][quoted image]
I don’t have a printer, but a buddy does... your tank looks amazing!
Is the blue water effect just a printed “card” attached to the back? It really looks like water in the pic. Would love to know how you achieved that effect!
Quoted from Chalkey:That sounds complicated but it looks amazing
Quoted from tominator:I don’t have a printer, but a buddy does... your tank looks amazing!
It's all LED's, the blue is a LED strip cut to about 4" ran along the underside of the tank cover on the rear side, the green is a LED strip cut to the same length ran under the tank cover along the front side, and the whites are individual LED lights one above each head towards their front to highlight their faces when lit. The pro has the programming in the code for the topper already so I used a 5 wire about thee feet in length, made a connector so it can be split from the PF to back box, tied all the commons together and the ran each hot to their individual pin on the plug on the cpu board.
I can send you the stl file for the bracket, after printed you can use some hot glue or goop etc to glue the tank to the bracket.
It should tie into the harness for the topper. Mezel Mods makes this, described as "Each head on the backboard is individually illuminated based on game play." I have this one with a bracket to mount the LEDs beneath the heads, but if I did it over I would likely leave them above the heads as they come from Mezel. I mounted mine with a piece of an old clear plastic that I glued to the tank and mounted using the same screws mentioned above. With the playfield back in position you can't see it at all.
Quoted from Gogojohnnyquack:It should tie into the harness for the topper. Mezel Mods makes this, described as "Each head on the backboard is individually illuminated based on game play." I have this one with a bracket to mount the LEDs beneath the heads, but if I did it over I would likely leave them above the heads as they come from Mezel. I mounted mine with a piece of an old clear plastic that I glued to the tank and mounted using the same screws mentioned above. With the playfield back in position you can't see it at all.
https://mezelmods.com/collections/walking-dead-pinball-mods/products/illuminated-fish-tank-walking-dead-pro
I seen this but it really would have been cool if they also added the Topper general illumination feature to it. That's why I just went ahead and made my own, and each head does interact like you stated when you make the fish tank shot.
What kind of GI and insert lighting did the Pro originally come with? I just bought one where almost everything was bright cool white LEDs. I switched them all out to warm white LEDs and to me, it looks much better. Were any released with incandescent?
EDIT: I see from the oldest YouTube videos that it was cool white, so these were probably original.
Quoted from DeathHimself:It's all LED's, the blue is a LED strip cut to about 4" ran along the underside of the tank cover on the rear side, the green is a LED strip cut to the same length ran under the tank cover along the front side, and the whites are individual LED lights one above each head towards their front to highlight their faces when lit. The pro has the programming in the code for the topper already so I used a 5 wire about thee feet in length, made a connector so it can be split from the PF to back box, tied all the commons together and the ran each hot to their individual pin on the plug on the cpu board.
Pretty sure i can Macgyver a way to mount the tank, but I would be really grateful for a wiring diagram and details in the lighting set up.
Sounds like by your description that you have two 4” strip leds plus 3 single white led’s all stuck to tank lid. Thats a lot of wires so I would like to know how you hid them and connected them... any pics?
Quoted from tominator:Sounds like by your description that you have two 4” strip leds plus 3 single white led’s all stuck to tank lid. Thats a lot of wires so I would like to know how you hid them and connected them... any pics?
That is correct, the Blue strip and 3 individual warm white LEDS are all hooked to the plug pins where the topper would go to, the green strip is on a constant 12v source where I used a variable POT to dim the green led's to my liking as this strip is always on.
I'll send you some pictures, along where I bought the pot.
Would anyone care to trade translites? I have @hassanchop’s Pro/Blood translite, and I’d prefer the same translite, but without blood. I have the original packaging with the sketch and limited edition stickers.
This is mine:
36E69980-BAED-45D6-B0F1-AD7109DD18CD (resized).jpegQuoted from tominator:Pretty sure i can Macgyver a way to mount the tank, but I would be really grateful for a wiring diagram and details in the lighting set up.
Here is a pic of a mount I made for the tank ,I superglued it to the back of the tank and it rests on the backboard ,iirc i put another 90 bend on the end to keep it snug on the bacboard
My Pro came with TiltGraphics blades. I pulled those out today, and installed the official Stern blades. I feel like Stern’s are better for this particular game, for lots of reasons. The zombies match the scale of the roads and toys on the playfield, and the colors seem like a better match too. I know art is really subjective, but I’d like to know what you guys think of these 2 options. First 3 are Tilt, last 2 are Stern.
Sorry for crappy photography.
116E1EFF-F90C-4E91-8270-7C2A981AFA8E (resized).jpeg74354338-B7CA-4F5C-9FF0-444C4C26F4DC (resized).jpegD73F7F4E-F3CA-4DB0-BB61-25C096F4E492 (resized).jpeg75F9AC9A-FF3D-4851-B9F6-0408E913458E (resized).jpegFD4E93C1-2B4C-43C7-8B5F-A3756BCD73A9 (resized).jpeg
I have stern ones but I still never understand why they have blood splatter on the sky? Just makes no sense to me. Other blades are similar with blood splatter like this.
Quoted from embryon:I have stern ones but I still never understand why they have blood splatter on the sky? Just makes no sense to me. Other blades are similar with blood splatter like this.
I just tell myself that I have blood on my riot helmet and that’s what I’m seeing.
Quoted from swampfire:I just tell myself that I have blood on my riot helmet and that’s what I’m seeing.
Good idea I must try that Lol
I think every WW should have some rope around him. Here’s the link to the twine I used:
https://www.amazon.com/dp/B07F63YH17
302355E4-3843-41B5-885C-388C37EC6B5D (resized).jpegQuoted from Chalkey:That is pretty frickin cool! Its synched to the prison flasher? Can you post a vid?
Made a quick and dirty video
https://photos.app.goo.gl/MQwTPFuozCPtL6Cs8
Problem is that effect on video is always less as real life. Have some dim leds tied to the GI which are thus on when GI is on and two flashers leds synced to the prison Flashers
Quoted from Fezmid:Luckily I was not having a particularly good game, but in the last ball, it somehow flew up, hit the glass, and landed here. By the time I went to get the key and take the glass off to put it in the shooter lane, the game aborted.
Interesting. My GOTLE and POTC have metal post there to prevent that, but my MET and TWD don’t. Always wondered what they were there for…
A light tap on the cabinet side would have gotten that.
Quoted from DNO:A light tap on the cabinet side would have gotten that.
I know, but was hoping to continue the ball, not have it drain!
Just joined this club, and my game has the Stern topper. My question is it easy to get inside the topper? One of the plastic sides is misaligned and I really need to get inside to fix it....its not readily obvious how to do this and wondering if anyone has done this before.
Thanks for your help
I just had a 120M crossbow shot, and I’m wondering how that’s even possible. I guess I could have had a good inlane multiplier built up, and 2X playfield running. I might have also started Crossbow Frenzy without realizing it. I love the big scoring opportunities in this game.
Quoted from Chalkey:If you watch the dmd long enough between games it should tell you
Thanks! I looked, and I guess 120M wasn’t enough to wipe my previous X-champion slot:
136,840,000…
A 4X multiplier shot that scored:
A Crossbow Kill worth 74,000,000
An Arena Shot worth 62,400,000
Setting up another massive Crossbow / Arena shot is my new goal.
Quoted from swampfire:Thanks! I looked, and I guess 120M wasn’t enough to wipe my previous X-champion slot:
136,840,000…
I've seen someone do a billion point crossbow kill. It's a tough strat to pull off, but can be super lucrative once you get the base set up for it.
Updating the rules doc and have some questions.
During a mode, how much time is added by completing the drop target bank? Is that variable based on settings? Same on Pro and Premium?
During Bloodbath is it 5,000 points per switch hit? Goes up by 1,000 if you complete the drop target bank again? Is there a maximum?
Starting Bloodbath the second time - does it take multiple sets of supplies? How many?
Spinners - how many points per spin? Different amount if Woodbury target is down? If so, how much?
Barn, Riot, and Arena modes - how much time initially? Variable based on settings?
Well Walker- "In the second stage, the “WELL” letters begin roving, repeatedly being spelled out. Hitting the Well Walker when the whole word is spelled offers the most points, while less to no letters at all scores significantly less" How many points?
Fun trivia question: how many names can you list for the zombies? For example, the Whisperers called them “guardians”. Another group called them “sickos”.
Here’s my last comment on the show itself, and then I’ll shut up for a while.
I got caught up tonight (finished season 10), and I highly recommend the final episode, “Here’s Negan”. It’s an origin story, and a really good one. Season 10 overall was a big redemption arc for Negan, and this final episode ties it up nicely. No spoilers - just go watch it, even if you skip the rest of season 10.
Quoted from swampfire:Here’s my last comment on the show itself, and then I’ll shut up for a while.
Thanks for posting this. The last five or six seasons I was watching on Netflix, so I was always a season behind. I just checked Netflix, and Season 10 starts Monday!
Quoted from Multiballmaniac1:Machine - For Sale
The Walking Dead (Premium/LE)
New!
HUO - Documented (Home Used Only) “Second owner less than 1,000 plays. LE #541
Minimal mods
Just bicycle girl light
Gorgeous game. Low balls will be ignored. No trades. Cash on glass only. No shipping.”9 hours ago
Western Mass, MA
8,500 (OBO)
Multiballmaniac1
Aw man. If only you were closer.
Quoted from Walk:Aw man. If only you were closer.
Take a trip
Price drop
New!
Minimal mods
Gorgeous game. Low balls will be ignored. No trades. Cash on glass only. No shipping.”8,000 (OBO)
Mark sale pending
Edit ad
End ad listing.
Has anyone came across the issue where you added a shaker motor (sterns) to the game and after a few seconds of performing normal the motor just runs continuously ever after ball drain and and game over?
I can tell you it's a Stern shaker kit with daughter board Rev A.
Game running latest code revision.
I'm leaning towards a bad or blown transistor.... and hopefully on the daughter board (shaker board).
TIA
Quoted from DeathHimself:I'm leaning towards a bad or blown transistor.... and hopefully on the daughter board (shaker board).
I don't have experience with that issue, but a failed transistor would not typically work and then quit when it gets warm each time. More like a connection getting warm like cold solder joint causing an intermittent control signal. Obviously the motor is getting power.
Quoted from Neal_W:I don't have experience with that issue, but a failed transistor would not typically work and then quit when it gets warm each time. More like a connection getting warm like cold solder joint causing an intermittent control signal. Obviously the motor is getting power.
I was think along the lines of the 22NE10L transistor blowing, if I'm correct they can blow and having the current constantly flow with no gate to stop it. However I kneel to those who are more electrically inclined them myself
I had an issue like this with my shaker on ACDC. I was told (by Stern) to get a revised board since earlier ones had issues.....but it required a different power wire so I couldn't easily use it without running a new wire. I gave up, put the old board back in and it magically worked and hasn't given me any problems in a while. Sooner or later I will need to figure this out.
Quoted from insight75:I had an issue like this with my shaker on ACDC. I was told (by Stern) to get a revised board since earlier ones had issues.....but it required a different power wire so I couldn't easily use it without running a new wire. I gave up, put the old board back in and it magically worked and hasn't given me any problems in a while. Sooner or later I will need to figure this out.
I have the revision A board which used the 22NE10L which I hear can blow at the drop of a hat, so of course I pull out the DMM and test the transistor and yep it's shot and locked wide open allowing the current just to flow through. I'm in the process of swapping boards with the distro as I only grabbed this yesterday and installed today, but I will be picking up a few of the upgraded 40 Amp N Channel Mosfet transistor from PBL just in-case this one blows again and replace the chip myself.
Yes I had the same issue. Did you notice the shaker was quite strong in it's shaking too? My issue was a faulty batch of pcb as I replaced tbe transistor and it blew soon after. You can try and fix but if you ply for an extended period it will blow again. Get a new pcb. I actually get mt supplier to rob a spidey vault that had been sited of it's pcb and no more probs.
If you have a really great game on a game you’re selling should you keep it? Just got to Horde on my LE for sale. I may have to take the ad down tomorrow. Horde is so badass.
Quoted from Multiballmaniac1:If you have a really great game on a game you’re selling should you keep it? Just got to Horde on my LE for sale. I may have to take the ad down tomorrow. Horde is so badass.
I have a TWD in my lineup that everyone hates when playing it. I too sometimes storm out of the room yelling, SELLING IT! But after a cooler head, I can still rock a kick ass game from time to time. So it is staying for now.
This page was printed from https://pinside.com/pinball/forum/topic/twd-club-only-walkers-not-welcome/page/204 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
