(Topic ID: 106132)
TWD Club, only walkers not welcome !!!
By pinball_erie
7 years ago
  • 10,525 posts
  • 672 Pinsiders participating
  • Latest reply 9 hours ago by PtownPin
  • Topic is favorited by 239 Pinsiders
11 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 10,525 posts in this topic. You are on page 194 of 211.
#9651 11 months ago
Quoted from Rickwh:
When I got my TWD prem last year, it had a colorDMD(LED version) in it. I have swapped it for a colorDMD(LCD version set on scan mode).
I posted pics in this thread so you can go back and see what it looks like.
Led version
Pro
Direct drop in replacement for stern dmd
Con
Grainy led resolution not ideal for TWDs dmd content.
LCD version
Pro
Flexibility of picking different modes small dots, large dots, square dots, etc.
Con
The lcd has spacers that make it sit back 1/2 inch or so away from the hole in the dmd panel. If you look at it from extreme angle you can see back into the back box some. If you had speaker lights that would probably have light bleed through. Can put foam strips or something to block the light.
IMHO, the colorDMD LCD set to scan mode is definitely the way to go for TWD.
A gasket has been produced to cover that gap and can be purchased direct from ColorDMD or direct from someone’s Pinside store too if I’m not mistaken, I forget who though
https://shop.colordmd.com/lcd-foam-gasket-stretch-fit/
#9652 11 months ago
Thanks guys, was looking at the colorDMD site and had seen that lcd was the way to go. If i can find a couple of people who want one here we can get free shipping for any 3 screens, saves about $100au each even after postage here in Australia to distribute.
#9653 11 months ago
LCD on it's way, decided i had enough energy to do the rails.
after
Horrible shooter rod goes next
#9654 11 months ago
OK so been having this issue for a while now...
Optos registering by themselves... prison doors (which is common) AND the drop target optos!
They both go to the little board under the playfield
So I'm guessing something on the board is bad. Maybe that surface mounted chip?
I have reflowed the prison door optos and reversed its connectors to the little board but since this affects the drops I think it is the board.
Anyone have a similar issue and hopefully solution?
#9655 11 months ago
any chance someone has a spare right inlane guide plastic? mine broke at the end near the flipper, it doesn't affect game play since the clear plastic underneath is fine but it doesn't look great. thanks!
#9656 11 months ago
Quoted from hisokajp:
Do you have a picture of what you need. I bought a plastic set and only used some of it.
#9657 11 months ago
Quoted from Jecco74:
Looks like -04
#9658 11 months ago
Looks like -04
I think I have an extra. I’ll be home late tonight to confirm. I’ll message you when I find out.
#9659 11 months ago
Hey all! So my right spinner on walking dead is bent and the arm appears to be as well. Can anybody point me in the right direction as to where I would get a replacement spinner and arm assembly? Switch is working just fine still. Thanks so much guys!!
#9660 11 months ago
Quoted from TheWombat2430:
I know you need the right side, but the left is all I could find on PBL or Marco's. At least this listing will give the part number for the left and a sense of cost. I would check your service manual to find the right-side part number, which is likely to be just one digit different than the left number, etc.
https://www.pinballlife.com/complete-spinner-assembly-with-switch.html
The last thing I will add is, the frame of any spinner can be bent into position. Not an indefinite number of times, but yes, the frames can be bent. Perhaps you could bend your frame and replace just the spinner:
https://www.pinballlife.com/desegastern-spinner-515-7088-01.html
#9661 11 months ago
Quoted from Jason_Jehosaphat:
I know you need the right side, but the left is all I could find on PBL or Marco's. At least this listing will give the part number for the left and a sense of cost. I would check your service manual to find the right-side part number.
Thanks so much for that! It looks like the same exact part just flipped upside down for the right side. I should be able to just do it that way no?? I’m examine and it looks to be the exact same setup!
#9662 11 months ago
Also, that doesn’t look like the right spinner size? I think it’s supposed to be a thinner model?
#9663 11 months ago
I don't have a TWD in front of me to study, but sure, there's a chance Stern just used a "left" spinner assembly on the right side of the playfield by simply flipping it around. The switch is actuated by the spinner, regardless of orientation, but the plastics are cut to accommodate the switch, so you have to be sure the left spinner assembly, when flipped, will sit properly in the cut-out.
#9664 11 months ago
I don't believe the Woodbury spinner is truly a "narrow" assembly, but I could be wrong. I would check the manual for part number to be sure though.
#9665 11 months ago
Looks like the part you sent me does match in terms of the full assembly. 511-5113-00.
#9666 11 months ago
I looked in the Service Manual posted online by Stern. Unfortunately, while they do include exploded diagrams of all the game-specific assemblies, I don't see the spinner anywhere. Maybe you do...
https://sternpinball.com/wp-content/uploads/2018/11/Walking-Dead-LE-Manual.pdf
#9667 11 months ago
If you look at Marco's listing for this same part, it's bilateral - which is to say it's not even side-specific:
https://www.marcospecialties.com/pinball-parts/511-5113-00
That suggests that Stern uses the same assembly and just flips it as necessary.
#9668 11 months ago
If you look at Marco's listing for this same part, it's unilateral - which is to say it's not even side-specific:
Precisely! Should be good. I can’t place an order with them until after Jan 2nd but it’s not the end of the world. Just wanted to make sure I can get the right part to make the fix accordingly! Thanks so much for your help!
#9669 11 months ago
This is driving me batty - I need to replace the blue bumper pad on my Pro (on right side of crossbow ramp) and I can't find the part # anywhere. Can someone point me in the right direction?
#9670 11 months ago
Quoted from nudgey:
https://www.pinballlife.com/stern-bnod-blue-nubs-of-death.html
#9671 11 months ago
There are 7 different ones linked here. I looked in the manual and on google but still haven't been able to figure out which one it is.
#9672 11 months ago
Quoted from nudgey:
Have you taken it off and looked at it? Should be able to narrow it down to two of those just by looking at it off of the bracket.
#9673 11 months ago
Quoted from nudgey:
If by "Crossbow" ramp you mean the Arena ramp, the blue bumper is for sale at Pinball Life:
https://www.pinballlife.com/stern-blue-rubber-bumper-626-5057-01.html
Or from Marco's:
https://www.marcospecialties.com/pinball-parts/626-5057-01
#9674 11 months ago
Received the Crate mod today and a big shout to Andrew who went above and beyond and delivered a great product
59977859-3870-44C6-A7E4-08D90BB1AD0E (resized).jpegBBF202F8-661A-4169-88D6-CBEB5B2D16EC (resized).jpeg
#9675 11 months ago
Going to be replacing the right spinner on my walking dead premium over the weekend. Should I remove the whole spinner assembly to properly put the spinner in? How does everybody usually replace a broken spinner? My first time doing this repair so I want to make sure I do it right! Thanks guys!
#9676 11 months ago
I’m picking up a pro tomorrow for the 2nd time. I had a sound mod on my first and can’t remember which version it was or where I got it from. Anyone know if they are still available and where to get?
Thx in advance
#9677 11 months ago
Quoted from SpinnerAddict:
Thx in advance
Hit up Cleland here on pinside.
#9678 11 months ago
#9679 11 months ago
Anybody looking for an LE, I am thinking about leaving the club.
#9680 11 months ago
Hey guys. Sorry if I'm the 900th person to ask this... on the premium can the bicycle girl ramp and crossbow be disabled in software to play like the pro, and if so is this the best of both worlds?
#9681 11 months ago
Ramp I’ve heard yes. I assume Xbow as well, given an operator probably would want to do that if it breaks
#9682 11 months ago
Quoted from Chalkey:
Yes, I have the ramp set this way for now. I also turned off the prison doors for the time being. Both due to excessive instances of the targets behind them not registering. When I have time to tweak those switches, I'll probably go back to normal. (Duh, if I didn't, there would be no point in tweaking the switches!)
#9683 11 months ago
folks - managed to find a nice LE to upgrade my premium from - just wondering those with LE's did you all get the upgraded harness? Not sure this has it - what does it look like and is there a part number for it?
Thanks,
Neil.
#9684 10 months ago
Hi guys,
What's everyone's opinion on the train track mod by Back Alley? Does it look good or does it detract in any way?
Thanks for any input.
#9685 10 months ago
Quoted from Drac:
It's beautiful and does not detract whatsoever. Purchase with confidence!
#9686 10 months ago
Quoted from NeilMcRae:
Thanks,
Neil.
Hi Neil, are you talking about the one that goes to the board under the playfield?
I remember something about this and sure mine was done, was Phil’s machine.
M4
#9687 10 months ago
Looking for some head decals for TWD prem.
Anyone have some they could part with?
https://pinside.com/pinball/forum/topic/wanted-twd-prem-head-decals#post-6059335
#9688 10 months ago
Quoted from Lostcause:
M4
yeah just not sure the game I've picked up will have it. It doesn't seem to have the bike girl ramp mod which I've got by the photos. Need the part number.
#9689 10 months ago
Theres a bicycle girl ramp mod here if Phil has none.
https://www.stern-spareparts.de/en/zombie-girl-ramp-modication-kit-502-6942-00_1297_1102
Maybe ask this company about the loom
#9690 10 months ago
Is it the UN11 power cable? Mine looks to have been changed, think the original one gets too hot.
Can’t find a part number, simple cable though.
EDIT. This is the cable I think https://www.stern-spareparts.de/en/stern-pinball-eu/power-supply-kit-twd-502-6952-00_1291_1096
#9691 10 months ago
Quoted from Drac:
Hi guys,
It's awesome, and looks like it belongs there. Every time I see one without it looks naked. One of my favorite mods.
#9692 10 months ago
Is $1250 for an original AMC Stern topper too much or is that a reasonable deal?
#9693 10 months ago
Quoted from EEE:
they were $399 new...
#9694 10 months ago
Quoted from EEE:
They are not available anymore... I paid $1500 for mine...
#9695 10 months ago
$1500 seems to be the going price on them
#9696 10 months ago
Quoted from EEE:
I've read $1200-1500 in multiple threads.
#9697 10 months ago
Quoted from Vimtoman:
yeah got it thanks just wish I'd found this:
ordered it thanks
Neil
#9698 10 months ago
I’m selling the Interactive backbox led kit from our machine.
Can any of you who have this mod tell me who the manufacturer is?
203BF1CA-7145-4273-B323-9C0F51AAC6E1 (resized).jpegDA7849BB-7F33-43F4-9813-F982473AC076 (resized).jpeg
#9699 10 months ago
Looks like DIY
#9700 10 months ago
Kim Keist made it.
