(Topic ID: 106132)
TWD Club, only walkers not welcome !!!
By pinball_erie
6 years ago
  • 9,756 posts
  • 634 Pinsiders participating
  • Latest reply 23 hours ago by Spiderpin
  • Topic is favorited by 217 Pinsiders
There have been 1,709 images uploaded to this topic. (View topic image gallery).
10 key posts have been marked in this topic (Show topic index)
There are 9756 posts in this topic. You are on page 190 of 196.
#9451 4 months ago
There’s a light associated with the walker head for the prison right? Tap into that.
#9452 4 months ago
OK I've tried everything to get my xbow to be more reliable and have failed imo. So I want to try and replace the cherry switch on the ball in position sw. Not sw 50 or 51 just yet.
Now I don't have the same brand in my stash but have the following two. Pic 3 is what's hooked up ATM. Would one of these two switches be compatible? Photo 1 with White actuator looks like its similar spec T85 where as photo 2 green actuator is T120. Or do I need to buy from stern at a silly price of nearly $50aud postage included
#9453 4 months ago
Quoted from Jason_Jehosaphat:
Better, More Creative Pin-Stadium Triggers for TWD?
Just wondering what better triggers users of Pin Stadiums have found on TWD.
Yeah, we all know about tying the flasher portion of Pin Stadiums to the Well Walker's flasher, but I would rather try something new. My original hope was to tie the lights to the Prison Walker Head's switch, but, sadly, one can't tie the lights to any switch on the matrix. Gotta choose a 4V-24 lamp or power source that's not on the matrix. What's working for you?
Thanks.
I would throw those pinstadiums out.. our group of friends really think it's the uggliest thing ever
People talking about 'what shoud I add next' gives me this image in my head..
#9454 4 months ago
Quoted from DavidPinballWizz:
People talking about 'what shoud I add next' gives me this image in my head..[quoted image]
That is AWESOME!!!!
#9455 4 months ago
Quoted from embryon:
[quoted image][quoted image]
The switches you have should be fine. Pop it in the game and see.
#9456 4 months ago
For those playing at home. I have had about a year of Xbow intermintent fails with times of few fails and days of lots. The symptom I had was the xbow would come off home slightly, stop, and then proceed to empty xbow itself.
Well I finally decided to replace the ball loaded in xbow switch diode. After 30 plus xbow loads during gameplay I have had no fails at all. I have switched the game off and on and still not fails. Early days but I'm feeling pretty confident after trying all the other fixes presented here.
So before going to the expense of replacing the motor mech try the diode and or switch beforehand.
#9457 4 months ago
Quick question, has anyone experienced an occasional multi-color flicker/strobe effect. It acts like a bad connection, but I'm unsure what to check. It is not constant and seems to be centralized to the Tunnel shot and surrounding lights in particular and only happens randomly.
I will try to get some pictures next time it happens if this is too vague a description. This is a LE version also. I am hoping it is easy to fix like the the strobe effect problem on the Metallica, all I had to do there was play with the connectors and it fixed it.
#9458 4 months ago
There’s a tiny connector on the big light board under the playfield. Towards the flippers. Find that and reseat it.
#9459 4 months ago
I will check that, thanks a lot! TWD is my favorite pin. It is terribly upsetting when she kicks my ass, but even more so when it doesn't function properly.
#9460 4 months ago
Does anyone know what battery TWD takes? Im not home and just remembered I need to order one.
#9461 4 months ago
Hey TWD fans - I'm selling my Laseriffic topper. It's too tall for my space.
https://pinside.com/pinball/market/classifieds/ad/101775
#9462 4 months ago
Quoted from Rager170:
According to the manual CR2430.
Must admit I am a little bit surprised it isn’t a cr2032 but the manual states this very clear. Replace with power on to retain the settings.
#9463 4 months ago
Quoted from Rensh:
Thank you!
#9464 4 months ago
Hey Chuck, after many games the problem appears to be gone and that looks like the issue, thanks again.
#9465 4 months ago
Quoted from Rascal-911:
Sweet! Happy to help. I would recommend to use some sort of zip tie or hot glue to hold that in place if it keeps wiggling loose. Pretty common issue.
#9466 4 months ago
Hi all,
I've noticed a strange problem with my pro. When I plunge the ball and try to time it for the skill shot I noticed that my star rollovers register but it doesn't hold? Therefore, it is impossible to get the skill shot. It's been challenging to try and fix as it lights up when the ball rolls over it but doesn't stay on for the skill shot/plunge. I hope that makes sense.
Thanks in advance for any help.
#9467 4 months ago
Quoted from Tuxedomask23:
Hi all,
This is a fairly common problem with this title. I've seen some folks twist or somehow alter their star rollovers. That seems to work. I have the same issue on mine, but it's actually 'more skillful' with mine. With my set-up, you have to time the shot, but also not fire the ball too fast. The 'slow plunge' allows my star rollovers to register.
Maybe give the 'slow plunge' method a try and see if that works (somewhat)? If not, then you can start making adjustments.
Cheers from Edmonton,
Winston.
#9468 4 months ago
I played about 10 games on my TWD Premium today. It was cruel as usual - balls being thrown to the outlanes left and right, drains from the pops, the unforgiving missed shots, the mean prison magnet, the meaner Bicycle Girl ramp.
Yet ... getting Bloodbath going, on top of Well Walker multiball, on top of Riot. The audio (w/ Cleland), the lighting, the total vibe!
I loved it!
#9469 4 months ago
Quoted from Tuna_Delight:
I loved it!
Recently added Dialed In and Tron which are amazing games too so have been neglecting my TWD, thanks for the reminder I will be having a few drinks tonight and getting my backside kicked as usual on this. Not so easy peesy lemon squeezy!!!
#9470 4 months ago
Quoted from wtuttle:
Winston.
Thanks for the help! What do you mean by twisting the rollovers? Unfortunately even slow plunging works intermittently.
#9471 4 months ago
Unmount the rollover, rotate it 180 degrees and mount it again. I needed to do this to one of my rollovers for it to register.
#9472 4 months ago
Winston.
The reason the slow plunge works is because the first rollover is slightly above the playfield causing the ball to ”hop” a bit and glide over the second rollover a bit too high to register fully. Had this problem on mine and after lowering the first rollover by a very tiny bit, i never have this problem.
Funny thing, is now I miss that you had to be skillful with the plunge like you said... just slow enough to not hop. Now, a fast full plunge will get it every time but definitely not as “skillful” as it used to be.
#9473 4 months ago
Quoted from Pinzap:
I am a hacker,I scroll to get the best option for the right rollover and fire away
#9474 4 months ago
Inspire by jasonjehosophat I switched out the white bumper bodies and skirts.
I was going to do translucent red for both but the black for the skirt looked badass so went with that along with the trans red body and red inlane guides
20200907_145428 (resized).jpg20200907_145441 (resized).jpg20200907_145417 (resized).jpg
#9475 4 months ago
Quoted from pinballjj:
yup... that’s the way to do it!
#9476 4 months ago
This only works for Woodbury skill plunge. There is no scroll option on the initial skill shot for each ball for the STAR rollovers.
#9477 4 months ago
deleted - dup post oops
#9478 4 months ago
Joining the club on Saturday if everything goes according to plan. Will probably be looking to get a new set of balls and rubber kit. I've never owned a game with a magnet, are there balls that are preferred for games with them?
#9479 4 months ago
You need carbon steel balls.
#9480 4 months ago
Good for you to sleuth out that fix!
Thanks for sharing, in case any of the rest of us end up in that position, too.
#9481 4 months ago
Quoted from beergut666:
Good for you!
Do you have your game set up?
How are you liking having your a__ handed to you?
I wish I could recommend truly shiny carbon-steel balls, but the only shiny balls I know are either Titan Super-Shiny or Ball Baron's Super-Ninja, and both are chromium steel. Ball Baron's carbon steel balls are okay, but not all that shiny. I would say that Pinball Life's common pinball is a *wee* bit shinier and, thankfully, it's carbon steel.
#9482 4 months ago
My Worst Mode:
I seem to always botch Arena. My Arena high score is well below the high score for any of the other modes.
I think this is the result of shooting Arena late after starting the mode and hitting Woodbury instead, instantly ending the mode. A one-and-done kind of thing. It's rare that I can hit a fistful of Arena ramps - and even rarer to do it while the mode is running! How about you? My record is probably four Arena ramps and then Woodbury. Maybe only three!
#9483 4 months ago
I was going to do translucent red for both but the black for the skirt looked badass so went with that along with the trans red body and red inlane guides[quoted image][quoted image][quoted image]
Oh, fork!
Those black skirts look superfly!
Awesome choice!
I may have to do a switch-a-roo!
Great photos!
#9484 4 months ago
Struggling with Cheap Drains!
I'm getting too many cheap SDTM drains from Arena ramp rejects. They happen when the ball gets tossed up there by the left sling just ten inches or so. Then it comes back with just the right trajectory to go SDTM. I find this happens once per game if not more. Plenty of examples of TWD rarely have this problem as their Arena ramps are mounted in a way that the ball gets a healthy bump from the Woodbury bumper as it comes back down into the playfield. I don't want to remount the ramp as I don't dare drill any additional holes. You can't really mount a one-way gate there at the foot of the ramp to stop/redirect the return because a return from the peak of the ramp would destroy it. I mean, I don't know of another ramp in pinball that is quite so long as Arena. A reject from the peak comes back like sledgehammer!
#9485 4 months ago
First Time Ever!
CDC shot that went to the crest of the ramp behind the back panel and came to rest. I had to jostle the game to encourage it on its way to the return side! That ever happen to you?
Oh, and I recently had the ball stall/park on the peak of a rollover lane. That was a mind blower!
#9486 4 months ago
First Time Ever!
I've had it sit on top of the roll over lane divider and the pop underneath them. Never had it sit behind the back panel. What's your pitch and side to side?
#9487 4 months ago
My Worst Mode:
Arena has been my best - 62m. I know that's nothing compared to others, but great for me. My others are around 20m. Tunnel shits me though.
#9488 4 months ago
I'm still having trouble understanding how to exit the Horde. I finished it a couple times where the flippers dropped and the ball was returned to the shooter lane. But I was never able to exit the Horde with a Woodbury shot, though I made the shot many times, with one or two balls in play, after finishing at least 3 rounds of kills. What's the deal here? I'm on version 1.56.
Also, hard prisons shots don't register consistently. Maybe 1 out of 3 shots. I have a carbon-like magnet protector and I seem to recall seeing somewhere it could be part of the problem. I hesitate to take it out if it's not going to make a difference.
#9489 4 months ago
Bought my pro nib off the first load at GOT PINBALL,florida amusement brokers here in Florida.
Noticed a "glitch" that the shot for extra ball, during multiball, will be returned to play with no ball added. There was a stubborn code install on the first code update and I ended up talking with a tech that said he had never heard of this.
extra ball addition works as it should when not in multiball.
Well , In spite of this being my only SS game as I have existed in the world of EMs all these years right up to the present, this glitch is still present today. It has the latest code updates as we have gone along for these years . has no other real issue, and I love the game.
Thoughts please?
thank you, I apologize if this is a redundant topic. this is my back yard neighbor.
#9490 4 months ago
Don’t shoot the EB shot while balls are still being autolaunched. The switch is turned off during that. The EB should award outside of that situation.
#9491 4 months ago
Quoted from lb1:
It is the carbon cliffy for sure. Remove it. You can use a piece of dental floss to pull underneath the lip to make sure that you don’t damage the playfield when removing. Then just remove any remaining glue.
#9492 4 months ago
Quoted from chuckwurt:
In addition, if the ball save is active, I don't think you get the EB either.
#9493 4 months ago
Quoted from lb1:
you are not "finishing" horde when the flippers go dead but getting " bit" . I would update to the latest code 1.6 as I think the horde escape through woodbury shot was only added recently to the code
#9494 4 months ago
Thanks a lot. I updated the code and I'll see how it works. I wasn't getting a bit message or loosing a ball so I wasn't all that clear as to what was going on.
#9495 4 months ago
Quoted from PBFan:
Protector removed with some floss and the shots are registering fine!
#9496 4 months ago
Quoted from lb1:
I think the chance to "escape" Horde is qualified by clearing a few waves of Walkers. You might even be able to set the number of waves in the S.P.I. game settings in the Service Menu.
#9497 4 months ago
Quoted from lb1:
Good that you licked that issue.
I find it hard to imagine that the Cliffy launches the ball above the opto's beam, but apparently it does!
#9498 4 months ago
Quoted from Fezmid:
I concur that EB's are often *not* awarded. Like, the shot is lit, and I hit it, and it's not awarded. I chalk this up to confusion. By that I mean, the code can't process the award because at that moment something else is happening concurrently and it's overload for the processor. Something like that. It happens to me once in a few games, for sure.
#9499 4 months ago
Quoted from weeze:
<snip>this is my back yard neighbor.
Is he your house guest from time to time?
#9500 4 months ago
Quoted from gumnut01:
62M for your best! Nice work!
Bowen mentions in his tutorial that the points available in Arena are scant and he doesn't invest much effort in the mode. Ditto: BG.
$ 26.95
$ 279.95
Pin Stadium Pinball Mods
