Hi guys, I have not asked for help on this as I didn't want to trouble people until I have exhausted everything I can think of. My xbow is unreliable in that I'll have a fail or two every 10 entries but it could be more.
I have adjusted xbow switches, bicycle girl, and prison head targets, disabled these switches as well as well walker and the optos. Even changed over the opto pcb. Adjusted pitch of game, turned shaker off, tried it at on all settings etc. Reseated connectors, put a washer under the swing arm of xbox, tightened/loosened pivot point of xbox.
Is there anything I've missed or could try. Each time I've had success, it lasts for 10-20 xbox cycles then a failure. One game it failed 4 times in a row. When it does, if it loads again during that ball, it will just auto fire otherwise the next ball it resets.
Now one thing I have noticed during in xbox test mode is every now and then after hitting sw51, instead of continuing right to do the 180deg approx swing, it will go immediately left back to home sw50. Then next test may do a normal rotation or it could do this 45deg and back home motion again. This occurance is quite random and most operations are the full rotation process that I figure is the correct cycle.
Is this short cycle movement normal and if not has anyone found what causes it? Now it is impossible to know if this short cycle would have occurred in the xbow failure as when it fails, it simply stutters at the start and then the yellow lights turn off and then it will swing out after a short delay and auto fire
