(Topic ID: 106132)
TWD Club, only walkers not welcome !!!
By pinball_erie
  • 8,271 posts
  • 556 Pinsiders participating
  • Latest reply 3 days ago by YeOldPinPlayer
  • Topic is favorited by 194 Pinsiders
There have been 1,404 images uploaded to this topic. (View topic image gallery).
10 key posts have been marked in this topic (Show topic index)
There are 8271 posts in this topic. You are on page 160 of 166.
#7951 80 days ago
Quoted from chuckwurt:
Try the zconnector like some one else suggested. If that’s making a poor connection I guess that could cause issues too. But to me it sounds like switch adjustment.
If I remember right, this is a normally closed switch so when you hit the WW, it opens and registers the hit. Pop the hood and see if when the WW is at rest, it’s barely pushing the switch closed.
Put the game in switch test while you’re doing this. If every little vibration is opening that switch, it could be your issue.
is it possible it was just the code I was using? Because I updated from Cleland old version to the official stern version and I think things are ok so far (crossing my fingers!)
#7952 80 days ago
Quoted from Oneangrymo:
Certainly a possibility.
#7953 80 days ago
I have isolated it to the flippers changing the code did nothing . If I use the left flippper sometimes It triggers well walker anyone know what to do now ?
#7954 80 days ago
You should be able to go into the switch matrix test and flip the left flipper and see if any other switches activate. Possible bad diode? Or just a very sensitive switch that is responding to vibration. Though the fact that it’s only the left flipper and not the pops or other flipper make me suspect a diode/matrix issue.
#7955 80 days ago
Had my best first ball ever... 60 kills! Drained and still had two extra balls to go, and ball 2 and 3...
End the game with 75 kills!!!!!! Pinball strikes again!
#7956 80 days ago
Jajajajajaajajjajaj
#7957 80 days ago
I think you guys are right it probably is the switch I’ll test it and see . I’ve always been confused how to use stern switch test. Do I just go to switch menu and should see it activate randomly if that is the problem?
#7958 80 days ago
Yes. Go there and manually activate other switches to get a sense of how the test works. When you activate a switch it will flash up in the screen with the name of the switch you’re activating.
#7959 80 days ago
If it is the switch bend the bar up away from the switch ? I won’t use that tool again and hopefully not snap it off like
Last time
#7960 80 days ago
Last time
Well not necessarily because the well walker is a normally closed switch. So you might need to bend it away from the well walker more so it takes more of a hit to him to register it.
When you snapped the first one it sounds like the metal actuator just popped off the switch. You could’ve probably snapped it right back on.
Put the game in switch test, pop the hood and play around with the well walker switch and get an idea for how it works. Once you know how it works, you’ll have a better understanding on how to fix it.
#7961 80 days ago
One other thing you can do is put it in switch test and bang on the play field with your fist a few times. That will let you know if its a vibration issues causing the switch to trip.
#7962 80 days ago
Another way to find if it’s the walker switch or some sort of matrix problem is to unplug the switch and see if the problem disappears (in test).
#7963 80 days ago
I just picked up TWD Premium. Woot!
Quick question - it came with the 1.6 Cleland ROM. I have never really heard the original ROM to compare the difference in sound. My first take is that the Cleland ROM has a lot of random call outs and many don't seem to be related to anything happening. Kind of reminds me of Data East games from the 90s that did the same thing.
How does the original ROM compare? I've heard that the -voice- of the callouts is kind of terrible, but does the original ROM use more instruction and does it actually related to what's going on in the game?
#7964 79 days ago
Quoted from mrgregb123:
Stick with Cleland (original callouts are shockingly bad). Have you got the PG or R rated Cleland code? If there are no kids around, go R, otherwise stick with PG.
10
#7965 79 days ago
Noooooooooooooooooooooooooooooooooooo!!!!!!
Had LMS lit and I bricked the Woodbury shot!
#7966 79 days ago
If that doesn’t cause you to light your game on fire, I don’t know what will.
#7967 79 days ago
You can try the original just so you’ll appreciate Cleland even more. You asked the right question though, because the ONLY thing the original has over the modified code is that some of the callouts are instructional in nature. But still nowhere near worth putting up with the hick callouts.
#7968 79 days ago
Man this is like the hardest switch ! I move walker back it triggers I bend him forward it triggers . I think I need to close the gap between switch and actuator ? I hope that fixes this once and for all very annoying cumbersome switch
#7969 79 days ago
Just look at it this way. Once you get it locked, you’ll be a pro at it! Haha
#7970 79 days ago
I had the same once.. but had another ball... and I even bricked that one too...
#7971 79 days ago
Quoted from DavidPinballWizz:
I don't know how heck you're supposed to even finish LMS... you need ANOTHER 115 kills once you start it!?! Unless you can light all the multikill weapons at once and start stacking kills somehow I don't know how it is possible to finish it.
#7972 79 days ago
I give up I’ll just have my pinball tech look at it and fix it he’s pretty good . I hope he can get it over with
#7973 79 days ago
Quoted from roar:
SPOILER: there are some rules you can obtain the 115 a bit quicker
#7974 79 days ago
I'm torn on whether I investigate it more or not as I'd love it to be a surprise if/when I make it there. After about 10 months of ownership I still haven't made LMS or Seige. Terminus only once but I can manage Horde somewhat frequently. I often have to just turn the game off in utter frustration.
#7975 79 days ago
For sure it's a brilliant game. The code and layout is one of the best. I've yet to make it to Horde though nevermind Terminus. One day!
#7976 79 days ago
Quoted from roar:
I don't even care about finishing it haha! I just want to get there and see the dots.
I'll make finishing LMS my next goal... Right now I just have to get it started!
After getting to 115 and missing, I think I need a few weeks away from pinball, or at least this game!
#7977 79 days ago
Quoted from zrbrt:
But seriously has anyone tried switching to warm white GI?
Yes. I switched the GI over to all Comet Sunlight and it is way better.
#7978 79 days ago
Quoted from Gogojohnnyquack:
I just joined the TWD club when I welcomed a pro version into my game room a week ago. I'm loving the game so far. I mean, it's kicking my butt, but the way it plays really suits the theme as you're constantly struggling to survive, so IMO they nailed it. I was just going to comment on the lighting though, as I just ordered all warm white for the GI from Comet as the cold white that came with it seemed to clash with the mostly warm toned art on the playfield and plastics. I think Comet's warm or sunlight LEDs (anything with a warmer spectrum) will do wonders.
#7979 78 days ago
The warm white LED comments got me motivated. I have too much glare from the white parts of the translite on my PF glass. I have some warm white LED replacements for the fluorescent tubes so just swapped one in. Its better. I then added a little bit of black tape by the AMC logo, the worst of the white, and the glare is nearly all gone now plus it has kind of a cool effect. Much improved for me!
#7980 78 days ago
Quoted from clg:
Post some pics when you can. I would be interested to see!
#7981 77 days ago
Yesssss plaseeeee
#7982 77 days ago
Quoted from Micky:
I don't have a before shot sorry. I noticed how different it looked with this bulb as it is right next to metallica with a LED tube. Much warmer light all in all and much less glare on the glass. It looks better in person but here is a picture.
#7983 77 days ago
Ok thanks!!!!!
#7984 77 days ago
If you do get LED Tubes you can get them MUCH MUCH cheaper if you buy from a lighting supplier or ebay than the pinball sites, they are very standard items to replace fluorescent bulbs not a pinball thing. Also very easy to install. As I recall I got 4 of them for about 25 with shipping on ebay. I put one in my TSPP for glare but sort of forgot about that.
#7985 76 days ago
I started switching my stock GI LEDs out for warm white.....and MAN, some of them are really hard to get to! Any tips, besides taking lots of pictures and just doing a small area at a time, so I remember where everything goes?
#7986 76 days ago
So I ended up trying out the original factory ROM after using the Cleland ROM for a few days. I realize this is an unpopular opinion, but I definitely prefer the original factory sounds. Sure, there's no post-season-4 callouts, but the ones in the Cleland ROM serve no purpose and are mostly random. Whereas the factory callouts are better placed and in many cases helpful. As far as the voice goes, it sounds enough like Yondu (I don't remember his char's name in TWD) that you can just pretend it is and it's totally fine. It's not nearly as bad as people say it is.
If there are any other 1.6 variant ROMs out there, I'd be happy to try them....
#7987 76 days ago
I agree with you. I absolutely appreciate the time and energy that goes into creating a custom sound package, but I prefer the original on this game.
As bad as the hillbilly guy sounds, he provides instruction. The TWD clips seem a bit randomized, but Cleland did the best with what he had.
#7988 76 days ago
Quoted from moonduckie78:
Grab a magnetic nut driver (1/4" I think), lift up the playfield, remove one socket at a time, replace cold with warm. Turn on the game with the playfield up to see what bulbs you missed.
For the ball guides on bottom, remove Phillip's head (2 or 3?) and pull the ball guides slightly out pull the 4 remaining GI from the top of the playfield, done!
I think it took me 20 minutes to do, well worth it!
You're not.. swapping the GI by pulling everything off the top side of the game.. right?
#7989 76 days ago
Quoted from zrbrt:
First time doing a full bulb swap like this. Fortunately, I have only done a few so far.....slings and ball guides...the stuff that was easily replaceable by removing a single plastic.....but yeah, i'm such a NOOB that I probably WOULD HAVE tried to pull everything off the top side. Thanks for the tip. That makes a WHOOOOLE lot more sense!!
#7990 76 days ago
Quoted from Mudflaps:
Maybe when you are new playing the game this is the case but having had TWD for years now I can’t disagree with this enough. The music and call outs on Cleland make the game a much more immersive experience for me. Red neck billy saying “shoot the ramp” does nothing for me because I already know what to do I guess.
The original has no actual sounds or callouts from the show and that is a huge miss IMO. I love hearing the randomized sounds from the show as it bring me back to remembering it.
#7991 76 days ago
And make sure you do this with the games power off. Don't use nut drivers or other tools with the power on. Just turn it on to check periodically.
#7992 75 days ago
I tried it and went back to original too... so you're not alone
#7993 75 days ago
Quoted from MikeS:
What he said
#7994 75 days ago
Same here. I've been through all of the alternate sound packages, from Slayer to NIN and through Cleland. They are all on USB sticks in the coin box. I really appreciate all of the work fans have done on these mixes but I keep coming back to the factory set.
#7995 75 days ago
Mine came with the Cleland code so I've never played it with stern callouts. I've never seen an episode of TWD so it probably doesn't matter how the stern one sounds...but
...i would like more helpful callouts. Do you get a lot more of them with stern?
#7996 75 days ago
Quoted from gliebig:
Yes. Only you can decide if you like them better or not. Find a The Walking Dead (Pro) on location near you and try it out. Or watch a stream. Elwin has a couple and Bowen did a tutorial on it.
#7997 75 days ago
Quoted from YeOldPinPlayer:
Ok. If I switch to Sterns most recent code, should I later want to switch back to Cleland...where do I find that? Since my game came with Cleland, I don't know where it came from.
#7998 75 days ago
If I recall there is a backup option in the UTILITIES menu. Backup your current code, try the stern standard code and if you want to go back, restore from your backup stick.
#7999 75 days ago
Quoted from luvthatapex2:
Cool. I'll give that a go.
#8000 75 days ago
Does that backup the CODE itself?? I thought it just backs up some of the Audit information, and maybe the high scores?
Sparky Pinball
$ 89.99
Trade
Machine - For Trade
Elkhart, IN
$ 445.00
MI Pinball Refinery
