Quoted from Oneangrymo:
I used a switch adjustment tool and the top metal thing broke right off the plastic switch. So I bought a new one and had some solder it for me and test it . It’s like brand new . That’s why I’m questioning if it’s actually the switch
Try the zconnector like some one else suggested. If that’s making a poor connection I guess that could cause issues too. But to me it sounds like switch adjustment.
If I remember right, this is a normally closed switch so when you hit the WW, it opens and registers the hit. Pop the hood and see if when the WW is at rest, it’s barely pushing the switch closed.
Put the game in switch test while you’re doing this. If every little vibration is opening that switch, it could be your issue.
