A friend has a colordmd led version which I could try out.
Made a quick movie to be seen at https://photos.app.goo.gl/or93babCgtCBgBtg8
I think I will like lcd better in a twd when I compare this video to some YouTube videos.
My Well Walker started registering phantom hits, is it time to replace the switch or is there an easy adjustment I can make?
I'm having a problem with my drop targets not resetting sometimes. It seems to work better if I open it up and manually lift them repeatedly, but that only seems to help for maybe 15-20 games. It seems it can be any of the 3 that's dropped last, so I'm unsure if it doesn't register that they're down or it fails to raise them, but the modes don't start when it happens, which is a huge deal to gameplay. They always come up fine on the next ball, so I'm at a loss(of course I have zero tech experience). Can't find anything loose, connections all seem good. Any suggestions would be greatly appreciated.
Quoted from Yngwie36:I'm having a problem with my drop targets not resetting sometimes. It seems to work better if I open it up and manually lift them repeatedly, but that only seems to help for maybe 15-20 games. It seems it can be any of the 3 that's dropped last, so I'm unsure if it doesn't register that they're down or it fails to raise them, but the modes don't start when it happens, which is a huge deal to gameplay. They always come up fine on the next ball, so I'm at a loss(of course I have zero tech experience). Can't find anything loose, connections all seem good. Any suggestions would be greatly appreciated.
Start by taking the glass off, get into the menu using the buttons inside the door, then navigate to Diagnostics Menu/Switch Menu/Switch Test. Then knock the drop targets down one by one to see if all 3 register as a switch hit. You should see an indicator on the display as well as a sound for each one. I suspect that one of them is not working. Hopefully it is just a broken wire on one of them that you can easily solder back on.
Quoted from Indusguys:My Well Walker started registering phantom hits, is it time to replace the switch or is there an easy adjustment I can make?
Major flaw with this game. I've had the same issue, as have many others here. The general suggestion seems to be to "form" (ie: bend") the switch to a more 'closed' position.
I do this and sometimes it works...for awhile.
The main problem is one of design: they didn't leave enough room to adjust this piece very easily. It could have been designed to allow for more more 'wiggle room'. That said, I'm not an expert or mechanically inclined, these are just from hours spent frustrated with this piece.
Cheers from Edmonton,
Winston
PS: try to avoid replacing the switch at all costs--it will cost you $60 to ship a $5 part from Marco's.
Your switch isn't broken, it is just too sensitive.
Quoted from Sparky:Can someone with a prem/LE measure the depth of the aquarium from the backboard to the edge closest to the player?[quoted image]
It's approximately 2-1/4".
I've played four different TWDs now (pro, premium, and LE models) and they all suffer from the same SDTM out of the pops and prison magnet.
For the pops, I can't see how it could be sorted out with a code update, as I believe the issue is a design flaw.
But the prison magnet drop is definitely avoidable. The magnet behavior can potentially be altered, or there can be a ball save out in place as they've done on many other games.
I know a lot of you have not experienced this issue, but there are definitely loads of people who have.
Come on Lyman!!!
If you are getting SDTM out of the pops, its a setup issue. I never have that happen. Prison, well, sometimes it happens. Most of the time on mine it doesnt, but occasionally it does. Same as it does on Metallica. A short ball save timer or a you hit no switches after the magnet activated timer would have been nice. It doesnt happen that often though. I would say I get more pissed off at the well walker magnet throwing the ball hard at the outlane and draining it. That happens way more to me than off the prison.
Quoted from wtuttle:PS: try to avoid replacing the switch at all costs--it will cost you $60 to ship a $5 part from Marco's.
Thanks, I will try bending it and see how that works.
Quoted from BrewNinja:If you are getting SDTM out of the pops, its a setup issue. I never have that happen. Prison, well, sometimes it happens. Most of the time on mine it doesnt, but occasionally it does. Same as it does on Metallica. A short ball save timer or a you hit no switches after the magnet activated timer would have been nice. It doesnt happen that often though. I would say I get more pissed off at the well walker magnet throwing the ball hard at the outlane and draining it. That happens way more to me than off the prison.
I am totally up for the idea that SDTM out of the pops being a setup issue... but if it is... how do I correct it? I do very little nudging on my pins so I'm guessing I am going to be even more susceptible to SDTM from the pop's than others but what slope should I be at? My bubble is in the middle and I'm level side to side on the game. It is entirely possible for me to drain SDTM with multiple balls in a row.
Quoted from roar:I am totally up for the idea that SDTM out of the pops being a setup issue... but if it is... how do I correct it? I do very little nudging on my pins so I'm guessing I am going to be even more susceptible to SDTM from the pop's than others but what slope should I be at? My bubble is in the middle and I'm level side to side on the game. It is entirely possible for me to drain SDTM with multiple balls in a row.
Increase the pitch a bit and see if that helps.
For most people giving it a tiny bit of lean to the left (instead of being perfectly flat) helps with the pop issue. There are other ways to do it though, its been mentioned in this thread a bunch. Some add a ring, some add some velcro.
Quoted from BrewNinja:For most people giving it a tiny bit of lean to the left (instead of being perfectly flat) helps with the pop issue. There are other ways to do it though, its been mentioned in this thread a bunch. Some add a ring, some add some velcro.
I'll mess with pitch and level, no way I'd add a ring or velcro though. That's just cheating
Quoted from roar:I do very little nudging on my pins so I'm guessing I am going to be even more susceptible to SDTM from the pop's than others
This is it right here. But if your game is setup good, the ball most times should bounce off the guide that hugs the left ramp, and go to the left flipper for a good dead bounce over to the right for a controlled shot. This should happen 95% of the time. The other times you’ll need to have nudging skills on the ready.
Set your game up steep too. Back legs all the way out, front all the way in.
In the first plunge of this video. That’s how it should happen almost every time.
I really have to disagree with this. I have 3 digital levels and OCD! Haha
You're not going to find many game more perfectly level than mine. I also believe in playing all games at 6.5 exactly as intended by their design.
You play steeper, you reduce the side drain, and I prefer not to do that.
Also, the fact that I've played all 4 machines, and saw the same issues, would mean every game is set up wrong. Impossible.
And the last one I played was a premium set up stupidly steep. Game was much easier to control than my game, but the SDTM issues still occurred.
Quoted from Damien:really have to disagree with this. I have 3 digital levels and OCD!
If you're having an issue with SDtM out of the pops then it's not 'supposed' to be level. Set the game up so the issue goes away.
Alternatively, play it as the designer intended and learn to nudge appropriately.
Quoted from YeOldPinPlayer:If you're having an issue with SDtM out of the pops then it's not 'supposed' to be level. Set the game up so the issue goes away.
I nudge like a mutha!
and if you are tilting the game off to one side then there is something wrong with the game. take a look in your manual. One of the first things that says is to level it perfectly side to side.
And really dude, a downvote? Your life that shitty?
Quoted from Damien:take a look in your manual. One of the first things that says is to level it perfectly side to side.
Your current solution of complaining more and ignoring the available solutions doesn't seem to be fixing the issue.
If you find a solution please share it.
Quoted from Damien:I really have to disagree with this. I have 3 digital levels and OCD! Haha
FWIW, it's a lot easier to have 4 machines set up incorrectly that 4 machines set up correctly.
Quoted from Indusguys:Thanks, I will try bending it and see how that works.
You can also try to either double up the spring on the WW or shorten the original. By having him not jump around so easily it stops the switch from opening with the slightest hit on the PF.
If you ask me, the fact the sling rubber is higher than the out lane rubber is more of a design flaw to me.
It’s a hard game, plain and simple. I think it’s probably too hard for some. Most people that walk up to it at my house play a couple of games then move on because it’s so hard.
Quoted from Manic:You can also try to either double up the spring on the WW or shorten the original. By having him not jump around so easily it stops the switch from opening with the slightest hit on the PF.
Thanks, I adjusted/bent the switch a little and now there are no phantom hits registering. FWIW I cut a small piece of slingshot rubber and wedged it between the guide by the left ramp where the ball should bounce off of and go to your left flipper. It works 90% of the time, and no nudging is necessary, I got the idea from somewhere in this thread. I am in the club that believes in a fair chance, a ball draining right out of the pops is just shit.
Quoted from Indusguys:Thanks, I adjusted/bent the switch a little and now there are no phantom hits registering. FWIW I cut a small piece of slingshot rubber and wedged it between the guide by the left ramp where the ball should bounce off of and go to your left flipper. It works 90% of the time, and no nudging is necessary, I got the idea from somewhere in this thread. I am in the club that believes in a fair chance, a ball draining right out of the pops is just shit.
Out of the Pops i did this and never had a drain out of pops for 2 years now
its just a big rubber i had from another game .
20190309_124410 (resized).jpgQuoted from stevevt:But have you ever played Tunnel mode?
all the time , smooth as butter
Quoted from thunderking50:try it , takes 15 min .
I would probably do something similar if my TWD had a pop-drain problem.
Quoted from Indusguys:I can also hit Tunnel very reliably with the rubber there.
You must be a great player. I can't hit that shot reliably WITHOUT the rubber installed!
Quoted from gweempose:You must be a great player. I can't hit that shot reliably WITHOUT the rubber installed!
Yeah hitting it is one thing... but to do it cleanly enough so it doesn't get hung up and go to hell by the pops is another
THEN... if you do nail it - it flies back around the outlane at such speed that when you nail the combo on the right ramp it has the propensity to fly right off... the velocity is just that great.
I know the train track mod would fix that but I don't like the way it blocks so much light on the right side of the PF. Anybody make a clear guard that's unobtrusive?
Quoted from Manic:Yeah hitting it is one thing... but to do it cleanly enough so it doesn't get hung up and go to hell by the pops is another
You defeinitely need to adjust something. Not sure how it’s flying off the right ramp. Even from a strong tunnel combo, should be smooth as butter up the arena ramp. Now when it’s returning down the left side of the game, you can add a piece of clear lexan to the top of the hump so it doesn’t ramp off from the speed.
The train track mod is on the return portion of the left ramp to the right of the right ramp. It's not on the right ramp (arena/fishtank/crossbow). That's the combo shot you're talking about, isn't it?
Quoted from chuckwurt:You defeinitely need to adjust something. Not sure how it’s flying off the right ramp. Even from a strong tunnel combo, should be smooth as butter up the arena ramp. Now when it’s returning down the left side of the game, you can add a piece of clear lexan to the top of the hump so it doesn’t ramp off from the speed.
Yeah oddly on mine it never jumps off the right ramp as it is returning down the left side. Only when I really nail it out of a left orbit and into the arena ramp shot. It can fly off maybe a foot or so up the right ramp. My machine may not be perfectly level - I've never had an issue (maybe rarely) of the ball going SDTM from the pops.
I'm a little hesitant to try to fix one issue and cause another. The fact you never have the issue makes me consider it. That could be the problem.
Quoted from Sparky:The train track mod is on the return portion of the left ramp to the right of the right ramp. It's not on the right ramp (arena/fishtank/crossbow). That's the combo shot you're talking about, isn't it?
Hmm.Maybe you are correct. From memory I thought it was a long piece of H.O. scale track laid over the right ramp. I haven't seen it lately so I'm probably mistaken.
Quoted from Manic:Hmm.Maybe you are correct. From memory I thought it was a long piece of H.O. scale track laid over the right ramp. I haven't seen it lately so I'm probably mistaken.
Quoted from NeilMcRae:make sure that the bottom pop is very sensitive and this is never an issue.
How do you make this adjustment?
Quoted from Captainhook:How do you make this adjustment?
There’s a switch blade under the playfield right under the pop bumper. Make the contacts really close together.
Quoted from TigerBall:For the longest time, I nudged the machine based off the DMD to prevent a SDTM. After reading elsewhere, I rotated the magnet a tiny bit and it it all but elimated the problem.
did same thing 2 years ago , i never had sdtm after that
Quoted from Manic:Yeah oddly on mine it never jumps off the right ramp as it is returning down the left side. Only when I really nail it out of a left orbit and into the arena ramp shot. It can fly off maybe a foot or so up the right ramp.
Mine does this as well sometimes on a super fast right orbit/right ramp combo. The ball flies off the ramp and ends up returning to the right flipper via the bicycle girl ramp return. My game is perfectly level at a seven degree slope.
I only saw a few pics, but has anyone put bloody hand/splatter decals on their TWD?
https://smile.amazon.com/dp/B07J4LDD2D/
This page was printed from https://pinside.com/pinball/forum/topic/twd-club-only-walkers-not-welcome/page/153 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
