I'm pretty sure that the distributor can get the felt pads to protect the playfield. I put a Cliffy on mine from day one because the "felt pad Stern fix-it" wasn't available yet. I'm really happy with the Cliffy. In fact, there are some dents in the Cliffy so I'm sure the BG ramp would be chewing up my playfield without it. Easy to install too.
Quoted from bigd1979:All it really is target foam put between the ramp flap and plastic lip of lift ramp.
so would you recommend it ... its only 8 bucks.
Quoted from robotron:Get the cliffy kit and don't look back. Includes the magnet protectors and the shooter lane also.
Are magnet protectors necessary on TWD? I was under the impression that the new design with the extended metal area around the core eliminated the need for them.
Quoted from hoby1:so would you recommend it ... its only 8 bucks.
I took my foam off and added a cliffy and am very happy with the results. Before the cliffy the mylar was getting chewed up even with the stern fix.
Quoted from gweempose:Are magnet protectors necessary on TWD? I was under the impression that the new design with the extended metal area around the core eliminated the need for them.
You are correct ....magnet protection not necessary on twd bc of the new style magnets
Not Necessary but I bought the wd le kit from cliffy there is still an edge there between the metal and wood. Rather be safe than sorry.
This page was printed from https://pinside.com/pinball/forum/topic/twd-bg-cliffy and we tried optimising it for printing. Some page elements may have been deliberately hidden.
